Alarm/Stereo Wiring for Toyota Corolla 1998
vseth
Copper - Posts: 60
Posted: April 18, 2005 at 9:21 AM / IP Logged
Need the following wiring information for the Toyota Corolla 1998 LE Automatic:
- stereo wiring
- wiring for remote starters
- wiring for alarm installation
- wiring for power windows/locks
thepencil
Gold - Posts: 1,526
Posted: April 18, 2005 at 9:41 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - TOYOTA / COROLLA / 1998 / Audio
[PRINT THIS PAGE]
Radio 12v
Radio Ground
Radio Ignition
Radio Illumination green   +   radio harness
Factory Amp Turn-on
Power Antenna
LF Speaker +/- pink(+) Violet (-)      radio harness
RF Speaker +/- lt.green(+) Blue(-)      radio harness
LR Speaker +/- black(+) Yellow(-)      radio harness
RR Speaker +/- red(+) white (-)      radio harness
Immobilizer Bypass Module: Required: No Type: N/A Part #: N/A
Notes: N/A
DIRECTWIRE™ WIRING INFORMATION - TOYOTA / COROLLA / 1998 / Remote Start
[PRINT THIS PAGE]
12volts white   +   ignition harness
Starter red   +   ignition harness
Second Starter
Ignition BLACK/ white   +   ignition harness
Second Ignition BLACK / YELLOW   +   ignition harness
Third Ignition
Accessory blue/red   +   ignition harness
Second Accessory
Keysense
Power Lock blue/black   -   R side of fuse box, wht plug
Notes: The lock wires are about 18 gauge. They will test only by operating the key in the passenger door lock cylinder, not the rocker switch on the door itself.
Power Unlock GREEN / WHITE   -   R side of fuse box, wht plug
Lock Motor blue      drivers kick panel
Unlock Motor red      drivers kick panel
Parking Lights+ green      bottom of fuse box
Parking Lights- lt GREEN/ black      steering column
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger RED / white   -   instrument cluster or
Notes: Also found at the fuse box. There are at least 5 RED / white wires at the fuse box, some will only pick up individual doors, meter them to find the one that will get all the doors, it will be the one that goes up to the instrument cluster, it is in a 12 pin plug on the back of the fusebox. For domelight supervision use one of the individual door triggers.
Dome Supervision
Trunk/Hatch Pin RED / white   -   light in trunk
Notes: On vehicle with the factory alarm, can find these wires at the alarm module above the drivers kick panel.
Hood Pin red   -   hood pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock
Tachometer yel/grn, RED / blu, gry, or wht   ac   any ignition coil
Wait to start
Brake Wire GREEN / WHITE   +   brake switch
Parking Brake
Horn Trigger GREEN/ red   -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Notes: N/A
DIRECTWIRE™ WIRING INFORMATION - TOYOTA / COROLLA / 1998 / Security
[PRINT THIS PAGE]
Disarm Defeat red      passengers kick panel
Hazards
Turn Signal(L)
Turn Signal(R)
Dome Supervision
Trunk/Hatch Release
Power Sliding Door
Disarm No Unlock
Memory Seat 1
Memory Seat 2
Memory Seat 3
Notes: N/A
DIRECTWIRE™ WIRING INFORMATION - TOYOTA / COROLLA / 1998 / Accessory
[PRINT THIS PAGE]
Headlight RED / white   -   steering column
Trunk/Hatch Release
Power Sliding Door
Speed Sense violet/white    4   center console 22 pin plug
Wipers blu/blk(L),blu/red(H   +   steering column
LF Window up/dn yellow - green   A   drivers door switch
RF Window up/dn grn/red - blu/wht   A   drivers kick panel
LR Window up/dn RED / grn - blu/blk   A   drivers kick panel
RR Window up/dn RED / blk - blu/red   A   drivers kick panel
Sun Roof open/close
Sun Roof Limit/close
Memory Seat 1
Memory Seat 2
Memory Seat 3
Notes: N/A
Be careful whose advice you buy, but be patient with those who supply it.Alarm/Stereo Wiring for Toyota Corolla 1998 - Last Post -- posted image.
vseth
Copper - Posts: 60
Posted: April 18, 2005 at 11:30 AM / IP Logged
Opened a new topic on power window modules in the car security forum, if you're familiar about their installations. Your input on the installation is much appreciated.
Thursday, March 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
