Amplifier blows fuses
elcamino82
Posted: May 07, 2005 at 11:40 AM / IP Logged
I recieved a Kenwood 800watt amp about 3 months back.  It has worked fined for the past three months running two MTX 10s.  Now it keeps blowing fuses.  I have checked all the wiring and made sure it is all set up correctly and that the ground is secure, yet the problems remaains.  Is the amplifier blown or am i missing some small detail?
DYohn
Platinum - Posts: 10,741
Posted: May 07, 2005 at 11:45 AM / IP Logged
The fuses on the amplifier blow?  Try disconnecting the speakers and turn it on.  If it blows, your amp is a crispy critter.
Platinum - Posts: 12,488
Posted: May 07, 2005 at 1:44 PM / IP Logged
If it doesn't blow with the speaker's unhooked, check to see if your power wire is grounding out anywhere with a DMM
ss-installer
Silver - Posts: 444
Posted: May 07, 2005 at 8:42 PM / IP Logged
what ohm load? amps will blow fuses quick with too low ohm loads.
