power window and door lock relay
placid warrior
Silver - Posts: 357
Posted: May 09, 2005 at 1:58 AM / IP Logged
Both the door lock and window work the same way so i can use 2 of the same relay, but i need to know what kind of relay I need and how to hook it up as I'm pretty clueless to this kind of stuff.
I have 2  wires for the door lock and 2 for the window motor...one wire has to be grounded while the other has power for it to open/unlock, then u ground the wire that had the power to it and put the power to the wire that was grounded to close/lock.  I want to hood up 4 push botton switches (2 for the lock and 2 for the window) one that locks/opens and one that unlocks/closes.
Do i just need a simple 4 prong relay or a 5 prong (or do i need something totally different)  I have a 4 prong (85, 86, 87, 30) and Ive used 5 prongs (85, 86, 87, 87a, 30)  I'm slowly learning how to use relays, but i was hoping that i could get some help cause its for a camaro that I'm working on and its supposed to be done in a week or 2 (have to do bodywork and paint too, so i dont want to have things that take too much time)  I would greatly appreciate any help with this situation.  Thanks.
placid warrior
Silver - Posts: 357
Posted: May 09, 2005 at 3:01 PM / IP Logged
oh yea...it would be those temporary on type push button switches that basically just complete a current so it would either have just a positive or just a negative wire to and from it.  Is it even possible to do with this kind of switch?
auex
Platinum - Posts: 5,041
Posted: May 09, 2005 at 3:57 PM / IP Logged
SPDT, single pole double throw. It will have both 87 and 87A, not all 5 pin relays have 87A. You would wire them for both locks and windows like the relay diagram for adding actuators.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
placid warrior
Silver - Posts: 357
Posted: May 09, 2005 at 4:03 PM / IP Logged
Ok! thanks auex, I appreciate the help.
placid warrior
Silver - Posts: 357
Posted: May 09, 2005 at 4:14 PM / IP Logged
Allright i just have to verify that i'm understanding this right.
this is the diagram.
power window and door lock relay - Last Post -- posted image.
The wires that go to the actuators are the wires that go the the lock and windows.  Do I add the switch between the wires that say - alarm(-) lock output/ input?  and both would be ground wires going to the switches right?  Thanks again for helping...i believe this is right but i dont want to fry a relay (cost me 7-8 bucks a piece)
auex
Posted: May 09, 2005 at 6:11 PM / IP Logged
That is the correct diagram. Your switches need to pass a ground. Then the other wire coming out of them will act as the alarm in that diagram, input wise. Don't forget fuses.
placid warrior
Silver - Posts: 357
Posted: May 09, 2005 at 6:30 PM / IP Logged
ah yes...fuses, almost forgot about em.  Thanks again for the help.
Saturday, August 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
