2003 GM full size pick-ups
jayts95
Copper - Posts: 150
Posted: November 17, 2002 at 7:07 PM / IP Logged
I have done a couple of these trucks.  (python 1500)  the locks are quite a pain!!  does anyone know where the keyless module is in these vehicles?  any help would be greatly appreciated.
thanks in advance
jason
Player69
Silver - Posts: 504
Posted: November 17, 2002 at 9:29 PM / IP Logged
The best thing you can do is get a data bus module for these.  All you will have to do is hook up 1 wire at the data link connector and it will do all your door lock/alarm functions.  Otherwise you have to go into the doors.
securinu
Silver - Posts: 772
Posted: November 19, 2002 at 1:33 PM / IP Logged
aamp part # dlgm4
petriej
Member - Posts: 7
Posted: November 19, 2002 at 4:58 PM / IP Logged
Is this also true for a 2000 Silverado? If so, what part #? Thanks.
Player69
Silver - Posts: 504
Posted: November 19, 2002 at 5:01 PM / IP Logged
No, 2000 you don't need this module.  You can get all the lock, unlock, disarm wires at the module under the steering column.
gechal
Posted: December 12, 2002 at 8:49 AM / IP Logged
It can be done w/o the data-bus module, but you have to put relays inside each door.  It sucks bad.   Data bus is definately the way to go.
g
Monday, June 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
