Commando KE-30 & 1997 F250
sadams71
Posted: May 13, 2005 at 10:15 PM / IP Logged
I've installed a Commando KE-30 on a 1997 Ford F250. Everything works except for the door locks and for some reason the valet switch doesn't work either.
After hooking it up and testing it the doors locked the first time but don't do anything now. Don't know if it helps but I checked the wires coming out of the unit and there is constant power coming from the door lock wires until a button is pushed, then the power drops and comes back up.
Scott
KarTuneMan
Platinum - Posts: 7,056
Posted: May 14, 2005 at 10:13 AM / IP Logged
Commando KE-30 & 1997 F250 - Last Post -- posted image.
chances are you have the wires from the relays 87a, and 30 backwards.....check the fuse that feeds the relay pack...
sadams71
Posted: May 14, 2005 at 12:21 PM / IP Logged
Thank you. That may explain it, I don't have relays on the locks. Where can I get the relay?
