Fixing chopped wires - stereo stolen
simona11k
Posted: May 16, 2005 at 2:53 PM / IP Logged
My stereo was stolen and I believe they chopped more than just the stereo wires because my speedometer, power locks and interior lights don't work anymore.  It smells like burnt rubber in the car too...
Tonight we are going to replace fuses but is it possible that wires to the dashboard were cut?  A whole bundle of 10 wires were chopped in total.  Is there anything differenct about installation when the wires are chopped? ... Anyone know any sites on general instructions I can use to go with the wiring info I got on this site?  I have a 93 Jeep Cherokee...
Cheers,
Wannabe Mechanic
KarTuneMan
Platinum - Posts: 7,056
Posted: May 16, 2005 at 3:38 PM / IP Logged
check your fuses.....
PuppyDawg
Copper - Posts: 92
Posted: May 16, 2005 at 6:50 PM / IP Logged
if you still need any kind of assistance identifing your stereo wires then let me/us know....be more than happy to assist...sorry bout your break in man....
P.S. oh yea....about your fuses....make sure you replace your fuses with the same size amp from what your factory suggested....
*paw print*
simona11k
Posted: May 18, 2005 at 3:40 PM / IP Logged
Thanks for the replies.  We changed the fuses and it fixed the interior light but the gauges and power locks are another story...
First of all, the fuses were missing (wonder if the thieves did it?) and when I put in the replacement for the gauges in, they flipped on and the power locks clicked back and forth a couple times then kept blowing out... wuh-ierd...
So my boyfriend goes and puts in a 30 fuse "to see where the problem is" and lucky me, the roof starts smoking then he takes it back out (same smell as when my car was busted into)... crazy/stupid approach eh?
...but he is proud to have "narrowed down the place to search"... any ideas of what is up in the roof? I'm thinking maybe the remote access is the prob... I think I am going to bring it to a shop for them to finish er off...
Any comments on my debaucle? Thanks for your offer PD...
Wannabe Mechanic
vseth
Copper - Posts: 60
Posted: May 18, 2005 at 3:52 PM / IP Logged
Make sure that because the stereo panel is off, that you have not disconnected any harnesses, eg. for emergency lights or clock . As you could have lost continuity in some of your circuits. In my car, when I remove the stereo panel, I have to disconnect the clock, emergency light and defrost harnesses, and as such until my panel is reconnected with the emergeny light harness, my turn-signal don't work, as disconnecting the emergency light harness breaks continuity in the turn-lights circuit.
thepencil
Gold - Posts: 1,526
Posted: May 19, 2005 at 1:25 PM / IP Logged
As per your request.
DIRECTWIRE™ WIRING INFORMATION - JEEP / CHEROKEE / 1993 / Remote Start
12volts red    +   ignition harness
Starter YELLOW /GREEN    +   ignition harness
Second Starter
Ignition blue    +   ignition harness
Second Ignition
Third Ignition
Accessory purple    +   ignition harness
Second Accessory
Keysense
Power Lock ORANGE / purple    +   drivers kick panel
Power Unlock pink/purple    +   same
Lock Motor
Unlock Motor
Parking Lights+ blue/red      drivers kick panel
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger yellow    -   underdash light
Dome Supervision
Trunk/Hatch Pin common with doors
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm GREEN/ orange    -   drivers kick panel
Disarm No Unlock
Tachometer gray/blue   AC   PCM
Notes: Powertrain control module located on left inner fender behind headlight.
Wait to start
Brake Wire white    +   brake pedal switch
Parking Brake
Horn Trigger black    -   ribbon cable st. col.
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Required:
No Type:
N/A
Part #: N/A
Notes: N/A
DIRECTWIRE™ WIRING INFORMATION - JEEP / CHEROKEE / 1993 / Audio
Radio 12v pink   +   radio harness
Radio Ground black   -   radio harness
Radio Ignition PURPLE / white   +   radio harness
Radio Illumination ORANGE / black (dimmer)   +   radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- dk. green - BROWN / red   +,- radio harness
RF Speaker +/- purple - dk. blue/red   +,- radio harness
LR Speaker +/- BROWN / yellow - BROWN / lt. blue   +,- radio harness
RR Speaker +/- dk blue/white - dk blue/orange +,- radio harness
Required:
No Type:
N/A
Part #: N/A
Notes: N/A
DIRECTWIRE™ WIRING INFORMATION - JEEP / CHEROKEE / 1993 / Accessory
Parking Lights-
Headlight BROWN / black    +   left of steering col
Trunk/Hatch Release
Power Sliding Door
Speed Sense
Wipers yellow      black box under dash
LF Window up/dn white - blue    A   in drivers door
RF Window up/dn pur/wht - brn/wht    A   in drivers door or dkp
LR Window up/dn RED / blk - blu/wht    A   in drivers door or dkp
RR Window up/dn grn/wht - gry/blk    A   in drivers door or dkp
Sun Roof open/close
Sun Roof Limit/close
Memory Seat 1
Memory Seat 2
Memory Seat 3
Required:
No Type:
N/A
Part #: N/A
Notes: N/A
Be careful whose advice you buy, but be patient with those who supply it.Fixing chopped wires - stereo stolen - Last Post -- posted image.
