Replacing the Alarm Speaker to Car Horn
percyv143
Copper - Posts: 77
Posted: June 01, 2005 at 3:21 PM / IP Logged
Hi. I have an alarm and it is currently connected to the speaker that came with it. My problem is the sound is too soft. Can I instead connect the output wire the the + side   of the car horn? Would there be any problem? Do I need to connect a fuse in series with the outout wire? Thanks.
davedyer79
Copper - Posts: 178
Posted: June 01, 2005 at 3:26 PM / IP Logged
Kinda need to know what year, make and model of the car along with the model # of the alarm.  If the alarm has a low current horn output, you need nothing.  Just plug the wire from the alarm to the car wire.  If not, you can use a relay to convert the siren's + output to a -output.
davedyer79
percyv143
Copper - Posts: 77
Posted: June 01, 2005 at 7:21 PM / IP Logged
my car is a celica 1989 ST manual and I just installed the car alarm myself. The wire that comes out from the alarm is color brown to be connected to the Siren (O/P +1A). Thanks.
OhioMike1101
Silver - Posts: 343
Posted: June 01, 2005 at 7:44 PM / IP Logged
Does the alarm have a horn wire?  If not, can you program the siren wire to be constant or pulsed?  You may not want a 35 second straight horn going off.  You can always buy a different siren.
percyv143
Copper - Posts: 77
Posted: June 01, 2005 at 7:49 PM / IP Logged
the alarm is pulsed. so i guess it will not be honking straight for 25 seconds :)
percyv143
Copper - Posts: 77
Posted: June 01, 2005 at 9:04 PM / IP Logged
My OEM horn wire is : GREEN/ BLUE (-)located at the STEERING COLUMN HARNESS. If my output wire is a + how will I connect the horn(-) wire? Is there a horn(+) wire in the steering column? What color? thanks.
auex
Platinum - Posts: 5,041
Posted: June 01, 2005 at 11:40 PM / IP Logged
Replacing the Alarm Speaker to Car Horn - Last Post -- posted image.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
percyv143
Copper - Posts: 77
Posted: June 02, 2005 at 6:40 AM / IP Logged
The alarm box has the model : OP168-6-C ... It's a generic car alarm that I bought from eBay. Thanks.
