Circut Breakers Vs Fuses
spootydlux4
Copper - Posts: 149
Posted: June 10, 2005 at 9:15 PM / IP Logged
Why do majority of installs use inline fuse holders, if a fuse blows u have to buy another one. so what if they're cheap, its still annoying, and hopefully you never have the problem of blowing fuses. But is there an advantage over circut breakers? Sorry if this is a stupid question, but im dumb and curious.
blah blah blah blah
stevdart
Platinum - Posts: 5,816
Posted: June 10, 2005 at 9:26 PM / IP Logged
For this answer, I'll refer you to Perry's website BCAE1.com under the following two titles:
http://www.bcae1.com/fuses.htm
http://www.bcae1.com/cirbrakr.htm
...in which he says
Circuit Breaker:
A circuit breaker's function is, like a fuse, to break a circuit path when a predetermined amount of current is passed. In my opinion, circuit breakers should never be used to protect electronic devices such as radios, amplifiers or crossovers. Most common circuit breakers (thermal snap action) take far too long to open the circuit path. This does not mean that they are not useful. When they are properly selected they do a good job of protecting wiring and devices such as electric motors.
But, basically, you're right...the majority of installs use fuses to protect the wiring.  But look at it like this:  you would have to be an SPL competitor to use a circuit breaker.  Any normal install should just use a fuse, and the fuse should never blow (well, almost never).  Any time a breaker opens or a fuse blows (talking proper value here), the indication is that there is a severe problem.  How many severe problems should an install have?
spootydlux4
Copper - Posts: 149
Posted: June 10, 2005 at 9:48 PM / IP Logged
Damn stevdart, you must be tryin really hard to earn a buck. I figured the answer to my question wouldve been on that site, but it is so big i didn't feel like looking. mainly i wanted to hear other peoples perspectives and viewpoints, but thank you.
blah blah blah blah
redpeppers
Silver - Posts: 483
Posted: June 11, 2005 at 12:18 AM / IP Logged
If a system is installed right then having a fuse or a circuit breaker doesn't matter.
Where theres is a wire there's a way.
Alpine Guy
Platinum - Posts: 2,478
Posted: June 11, 2005 at 9:06 AM / IP Logged
If its insalled right you should never blow a fuse, in all my life i have never blown a car audio fuse.
oonikfraleyoo
Gold - Posts: 1,069
Posted: June 11, 2005 at 10:18 AM / IP Logged
God knows I have.Circut Breakers Vs Fuses - Last Post -- posted image.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
kgerry
Platinum - Posts: 3,455
Posted: June 11, 2005 at 11:49 AM / IP Logged
totally subjective answer... but i've always worried about the "possibility" of a circuit breaker arcing closed and not doing it's job vs. a fuse in which this can't happen.... i've always felt more comfortable protection wise by fusing my primaries vs. CBing them......
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
kd7nfr
Copper - Posts: 71
Posted: June 11, 2005 at 3:59 PM / IP Logged
Never blown one either. Hell, most people around here are so cheap they wrap the fuse in tin-foil. One day they'll learn...
Sunday, July 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
