4000ppm to 8000ppm conversion, how to?
cable43
Posted: June 22, 2005 at 8:02 AM / IP Logged
is their a way to use a combination of resistors and capacitors to boost a 4000ppm VSS signal to a 8000ppm signal?
Basic story:
I have a speed activated unit that is looking for a 8000ppm vss signal.
My car only puts out 4000ppm.
I believe the unit will activate if I go twice as fast (i.e. if it will activate at 25mph I need to go 50mph but i would like to boost the signal if i can.
I know there is a way i just need a formula or an good example.
is any of his making sense to anyone????
is there anyone with some experience that can help???
warmshed
Posted: July 01, 2005 at 12:18 PM / IP Logged
You wont easily convert a 4000 PPM to 8000 PPM but most cruise controls will have adjustment to cater for the lower PPM, check out the installation book. Audiovox is adjusted by the little switches inside the controlcard on the end of the servo unit. What make is the unit you are trying to use?  Dave.
cable43
Posted: July 01, 2005 at 5:48 PM / IP Logged
this is for a custom application (not ac CC)
i have found a solution- well i still need to build it but it may work.
thanks
Cable
***** here's what i need to make
Cav3Kim
Member - Posts: 16
Posted: August 15, 2005 at 5:51 PM / IP Logged
Hi Cable, what solution did you find for this?
I'm going to try and do something similar,
thanks
Richard
cable43
Posted: August 16, 2005 at 5:51 AM / IP Logged
here is what I came up with:
4000ppm to 8000ppm conversion, how to? - Last Post -- posted image.
here is is after it was just about done:
I have yet to see if it works but it is a simple clock doubler.
