Adding cruise to a 2005 silverado
mongo
Posted: July 02, 2005 at 9:41 AM / IP Logged
Anybody have a wiring diagram for a 2005 silverado?
mo12v
Posted: August 03, 2005 at 3:33 PM / IP Logged
Should be D B W................Just get a Chevrolet Turn Signal/ Cruise Control Lever $120.00 from GM Parts
PM me for wiring Instructions for Factory handle
Otherwise:
SILVERADO 4.3L
VSS Wire: LOCATION14- FACTORY 10 PIN CONNECTOR POSITION K
VSS Wire Color: GREEN / WHITE
VSS Pulse: 4000
VSS Tach Wire: LOCATION 15- RED CONNECTOR OF ECM POSITION 10
Tach Signal Wire Color: WHITE
Brake Switch Positive: ORANGE
Brake Switch Negative: WHITE
MO
