upgrade wire?
jaymes
Copper - Posts: 47
Posted: July 02, 2005 at 1:58 PM / IP Logged
so i just put in a High output alt in my car. THe factory wire runnning from the alternator to the battery seems small.. . Looks 8 awg. Should i upgrade the wire as i am going to be charging two batteries?
haemphyst
Platinum - Posts: 5,059
Posted: July 02, 2005 at 2:25 PM / IP Logged
You could be charging a hundred batteries, and it wouldn't necessarily mean you had to change your output wire... You base THAT decision on how much current your alternator can produce. How big is your alternator?
jaymes
Copper - Posts: 47
Posted: July 02, 2005 at 2:38 PM / IP Logged
alternator is 150 amps
Poormanq45
Silver - Posts: 597
Posted: July 02, 2005 at 2:56 PM / IP Logged
Normally the wire going from the alternator to the battery is about 2ft long. it's probably 4awg wire. It should be fine
Blowntweeters
Silver - Posts: 650
Posted: July 02, 2005 at 3:24 PM / IP Logged
if it is 8awg upgrade to 4awg
1974 ford pinto 4 15" punch Z power punch bd 1001 pioneer DEH-6700
Friday, July 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
