gm twilight sentinel
dalemc
Posted: November 26, 2002 at 4:49 PM / IP Logged
anyone know the best method to bypass the twilight sentinel headlight feature on a 1999 chevrolet truck and use swith manually-thanks
dalemc
Player69
Silver - Posts: 504
Posted: November 26, 2002 at 8:32 PM / IP Logged
push the park brake one notch before you start the truck.
djfearny2
Silver - Posts: 810
Posted: November 26, 2002 at 8:34 PM / IP Logged
this works for pretty much all cars that have day time running light.
Jon
Installer/Help Technician
---coral springs florida---
jrilla
Gold - Posts: 1,498
Posted: December 06, 2002 at 1:10 PM / IP Logged
I haven't Tested this on my car yet, but I was reading this and I know it will work for the daytime running lights, but what about the twilight sentinel?  When it gets dark th elights come on, or even if i cover up the sensor on the top of the dash.  I never have to touch my headlights, but then I cannot turn them off while driving, I mean I have try by shootings to do and I have to borrow my wifes car if I want to have the element of surprise on my sidegm twilight sentinel - Last Post -- posted image..
J Rilla
Owner/Installer
SnomanF150
Silver - Posts: 269
Posted: December 09, 2002 at 8:25 PM / IP Logged
on the chevy SUV's and Trucks, press the domelight override button on and off three times.. this will turn it off.. I don't know if it will stay that way if you turn the key on and off and on again.. but when we are doing system checks and the lights come on, just hit the override button and kill the lights.. for the cars, I don't know how to turn them off completely, but if you want to creep up on someone, just pull the switch to parking lights, it will kill the headlights..the parking lights will be on, but, from what I remember, every time I see a drive by in the movies, the parking lights are always on, and then they turn on the headlights to drive away..
George
David's Car Stereo
Baton Rouge, LA
jrilla
Gold - Posts: 1,498
Posted: December 09, 2002 at 8:35 PM / IP Logged
Hey Snoman, I know it is going to an extreme, but could you put one of the wires that control the sentinel on a switch that would basically disconnect the wire to disable just the sentinel and allow normal light switch operation using their factory switch?  I'm sure i would have to test for which wire to use.
J Rilla
Owner/Installer
SnomanF150
Silver - Posts: 269
Posted: December 09, 2002 at 8:48 PM / IP Logged
I don't know if any of that is going thru the BCM.. I'm sure it is.. I've never really thought anything about it.. I know on the older caddies that there was a switch on the dash above the light switch.. also had a timer for it to shut off..
With all the stuff these days using a BMC, ECM, ECT... I would want to fool with anthing like that unless I had a schematic for it..
George
David's Car Stereo
Baton Rouge, LA
DavidL
Posted: December 15, 2002 at 9:45 PM / IP Logged
Don't know what model '99 truck he's talking about, but I 've got a '98 Blazer ZR2 I did this to. The sensor is a photo diode if I recall correctly and mine was in the passenger side dash speaker grille. I used a 2 or 3 volt zener diode to make the computer think the vehicle is in sunlight all the time. Pull the plug off the sensor and insert diode, tape and hide under grille. Unused sensor can be left in the hole in the grille. No cutting or anything. Did this in May of '98 and no problems so far. DRL's still worked fine, but that was the next thing to go. Pulled the diode in the fuse box. That won't work on newer models I've heard though.
David
jrilla
Gold - Posts: 1,498
Posted: December 16, 2002 at 6:38 AM / IP Logged
I was looking for a much more temporary method of shutting off my lights.  I like not having to touch my headlight switch, that way I never leave them on or more importantly forget to turn them on.  I'm not saying I'm one of those idiots who go driving down the freeway without my lights on, but it is nice to not have to turn on and off lights.  If anyone knows of a way to put a switch on the sentinel and the DRL (since overriding the sentinel would still leave me with daytime running lights.)
J Rilla
Owner/Installer
TomEllis
Copper - Posts: 52
Posted: December 16, 2002 at 1:33 PM / IP Logged
Use the method that DavidL mentioned above only install a dpdt switch in line. That way it would be either manual or automatic depending on the position of the switch.
You could do the same with the DRL's as well.
Tom
Friday, August 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
