12volt to 1.5volt.
Audioman013
Posted: July 11, 2005 at 8:50 PM / IP Logged
What size resistors do I need to achieve this? Do you think this is possible? Thanks for your help in advance.
geepherder
Platinum - Posts: 3,668
Posted: July 12, 2005 at 6:56 AM / IP Logged
Yes you can do this with resistors, but it's not as simple as you may think.  Any resistor can drop any voltage any given amount.  It depends on the total resistance of the circuit, and a few other variables such as current and power demands.  If you tell us what you're trying to do, I'm sure someone here can help you out much more.  I pop my head in here when I can, but you'll find plenty of more helpful/knowledgeable members here.
Audioman013
Posted: July 13, 2005 at 7:15 PM / IP Logged
I'm trying to hard wire an MP3 player on my buddys street bike. It uses only 1 AAA battery. If I can do this than we will use it or if not then he will get an iPOD. Thanks again.
geepherder
Posted: July 13, 2005 at 8:19 PM / IP Logged
A simple bleeder resistor in series, with the mp3 player, and a zener diode rated at 1.5 volts will do it.  I'm not great at explaining these things, so do a search on google for zener diodes.
Audioman013
Posted: July 13, 2005 at 9:34 PM / IP Logged
Thanks.
Ween
Platinum - Posts: 1,368
Posted: July 13, 2005 at 10:54 PM / IP Logged
hi,
you might not find a zener rated at that low of a voltage.  might be able to use a few 1A diodes in series instead.  you'll need to know the current draw of the player also to set up the regulator circuit properly.
hope this helps,
mark
Mad Scientists
Silver - Posts: 380
Posted: July 16, 2005 at 11:57 AM / IP Logged
Use a standard voltage regulator instead.. the problem with using a resistor bridge is that your input voltage does change; a zener diode is better, but uses more power.
Jim
Evolution-UK
Copper - Posts: 192
Posted: September 18, 2005 at 6:26 PM / IP Logged
or buy a 12v multi-voltage adapter from your local electrics store.
http://www.maplin.co.uk/Module.aspx?ModuleNo=45348&doy=19m9D
