fog lights trouble shooting
916k
Member - Posts: 9
Posted: July 16, 2005 at 12:59 PM / IP Logged
i  bought aftermarket fog lights and installed them with their own wiring kit, everything is correct, as far as wiring. but my right fog light is dimmer than the left, and i'd like to know why?
916k
916k
Member - Posts: 9
Posted: July 16, 2005 at 1:01 PM / IP Logged
it's installed on a 2000 mitsu. mirage de 1.8L 4dr....by the way
916k
Mad Scientists
Silver - Posts: 380
Posted: July 16, 2005 at 1:21 PM / IP Logged
measure the voltage to the fog lights, and check for good ground. My bet is on a bad ground.
Jim
916k
Member - Posts: 9
Posted: July 16, 2005 at 5:55 PM / IP Logged
should i do a voltage drop test on it ?
916k
916k
Member - Posts: 9
Posted: July 16, 2005 at 5:58 PM / IP Logged
as far as the bad ground ,i checked the ground from the light to the harness...and i connected the gnd to the batt. gnd, is that ok, or should i put it to the frame of the car?
916k
916k
Member - Posts: 9
Posted: July 16, 2005 at 7:18 PM / IP Logged
i connected the ground to the frame i sanded of the paint to bare metal. the gnd is  good but as the volts go ..... the left pulls in more volts by like 3v more than the right, ....what should i do now?
916k
nowlater123
Copper - Posts: 61
Posted: July 17, 2005 at 2:30 PM / IP Logged
If the problem is not with the wires, the light itself may be faulty. Maybe if you exchange it, they might work beter. Sometimes new stuff doesn't always work perfectly.
Kenwood all the Way!
bxscig
Copper - Posts: 41
Posted: July 21, 2005 at 12:29 PM / IP Logged
Were they hooked up in series or they draw power from the the battery directly?
Monday, July 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
