85' chevy celebrity
nicktagz
Posted: July 21, 2005 at 3:47 PM / IP Logged
85' chevy celebrity
thepencil
Gold - Posts: 1,526
Posted: July 22, 2005 at 12:31 PM / IP Logged
1986 is the is as far back as I have on the information relating to your car.
DIRECTWIRE™ WIRING INFORMATION - CHEVROLET / CELEBRITY / 1986 / Remote Start
12volts
Starter yellow      ignition harness
Second Starter
Ignition pink      ignition harness
Second Ignition
Third Ignition
Accessory orange      ignition harness
Second Accessory
Keysense
Power Lock lt blue    +   driver kick panel
Power Unlock black    +   driver kick panel
Lock Motor
Unlock Motor
Parking Lights+ brown     at switch or driver kick
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger white    -   underdash light
Dome Supervision
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release black    +   at switch or driver kick
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer
Wait to start
Brake Wire white      brake pedal switch
Parking Brake
Horn Trigger
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Be careful whose advice you buy, but be patient with those who supply it.85' chevy celebrity - Last Post -- posted image.
