2003 Chrysler Sebring GTC Alarm Wiring
gaines
Posted: July 23, 2005 at 1:32 AM / IP Logged
I'm getting ready to install my first alarm system (Viper 790xv) and want to be absolutely positive that I understand the wiring since it will include remote start. I would greatly appreciate any information you can provide.
thepencil
Gold - Posts: 1,526
Posted: July 25, 2005 at 9:54 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - CHRYSLER / SEBRING COUPE / 2003 / Remote Start
12volts WHITE/ red   +   ignition harness
Starter BLACK/ red   +   ignition harness
Second Starter N/A
Ignition dk. green   +   ignition harness
Second Ignition
Third Ignition
Accessory blue/red   +   ignition harness
Second Accessory blue/black   +   ignition harness
Keysense
Power Lock purple   -   driver kick, blk 32 pin plug
Power Unlock lt. GREEN/ red   -   driver kick, blk 32 pin plug
Lock Motor lt. green   5wi driver kick, blk 32 pin plug
Unlock Motor dk. GREEN/ red   5wi driver kick, blk 32 pin plug
Parking Lights+ GREEN / WHITE or pink/black   +   low in driver kick
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger GREEN/ YELLOW   -   fuse box
Notes: Located in a black 19 pin plug on the back of the fuse box under the driver side dash.
Dome Supervision GREEN/ orange   -   fuse box
Notes: In the plug on the upper right side of the fuse box under the driver side dash.
Trunk/Hatch Pin red   -   driver kick, wht 43 pin plug
Hood Pin
Trunk/Hatch Release GREEN / WHITE   5wi driver kick, wht 43 pin plug
Power Sliding Door N/A
Factory Alarm Arm lt. GREEN/ black   -   driver kick, blk 32 pin plug
Notes: These are the door key cylinder wires. Meter the wires while turning the key in the driver door.
This will also lock the doors.
Factory Alarm Disarm orange   -   driver kick, blk 32 pin plug
This will also unlock the doors with a double pulse.
Disarm No Unlock see factory alarm disarm
Tachometer white or WHITE/ red   ac   test connector
Notes: Go to the test connector inside the fuse box under the hood, it is a T shaped plug. Tach is the terminal on the top left of the T, the wire under the terminal is white or WHITE/ red.
Wait to start N/A
Brake Wire GREEN/ orange   +   brake pedal switch
Parking Brake
Horn Trigger lt. GREEN/ black   -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: 555U
Notes:
Be careful whose advice you buy, but be patient with those who supply it.2003 Chrysler Sebring GTC Alarm Wiring - Last Post -- posted image.
