turbo timer bypass
ringojam
Copper - Posts: 215
Posted: July 24, 2005 at 12:47 PM / IP Logged
Need a diagram for a turbo timer bypass.Problem i have a evo 8 with a viper hf350 alarm apexi turbo timer, i want to arm my system while turbo timer is still running.This car is a jdm model right hand drive.
iskidoo
Silver - Posts: 1,048
Posted: July 24, 2005 at 5:20 PM / IP Logged
You would need a relay to interrupt the shock sensor as well as another relay to interrupt the ignition input to the alarm. The ignition input H1/9 YELLOW (+) Switched Ignition Input, Zone 5 needs to be interrupted as it is also a triggerable alarm zone. IE. turning the ignition on while armed will set off the alarm. Wire a relay that uses the ignition as a feed on pin 86. Ground pin 85. cut the lead going to the sensor and/or ignition input and wire one side to pin 87A and the other to pin 30. I think that might work. Whenever the vehicle is running the relays will bypass those zones via the relays. While the engine is running you get out of the car, close the door and then arm the alarm with your transmitter. When the turbo timer shuts down, the sensor and/or ignition input will be active again.
Anyone else have a better way? There could be an easier way but this is all I can think of at the moment. Use this diagram as a reference. I don't think you would need the diode.
turbo timer bypass - Last Post -- posted image.
Steve G
