how long should a remote start take???????
mobiletoys2002
Gold - Posts: 1,050
Posted: November 29, 2002 at 10:57 PM / IP Logged
hey guys im not a newbie but i would like to knowewhat others think how long a good install should take on  a remote starter i love to solder  and do my connections good.and i think my boss wants me to be quiker what you guys think to do an install from start to finish of course not using t taps.
Platinum - Posts: 12,488
Posted: November 30, 2002 at 12:12 AM / IP Logged
Basic vehicle without keyless entry, no immobilizer and no additional accessories: About 1.5 - 2 hours depending on if I had worked on a similiar vehicle before.
A vehicle with immobilizer bypass rewuired and keyless entry ( type C ) : About 3 -4 hours depending on if I had worked on a similiar vehicle before.
Additional accessories require more time like trunk release, power door lock actuators & window modules.
Sound Pressure
Silver - Posts: 711
Posted: November 30, 2002 at 3:24 AM / IP Logged
Hey mobiletoys,
Your boss should worry about quality and not quanity. Unless he want's more and more than there can be a possiblity of returns for problems which will take you away from producing more and fixing more. I agree with Jeff on the amount of time those tyoe of installs should be considering all connections are soldered. That's the only way that I do all my connections. It's S.S.S.=Solid,Secure,and So neat!how long should a remote start take??????? - Last Post -- posted image.
Sound Pressure
mobiletoys2002
Gold - Posts: 1,050
Posted: November 30, 2002 at 7:29 AM / IP Logged
see know thats about what it takes me sometimes i even do it a little quiker and get a car done in about  1hour and15 mins or so but when a car comes in with all these things needed to be done 5 wire door locks,immobilizer bypass,trunk realease,oem integration there is no way i can do it in an hour,he wants to see 8 cars done in a day, well he needs to get the clients before he even thinks about doing 8 cars a day. anyways take it easy guys and thanks for the reply.
Posted: December 01, 2002 at 9:54 AM / IP Logged
Here is a way to do alot more than 8 cars a day.... have you ever tag teamed a installation ? It take about 40 minutes to do an alarm/ RS installation with all the bells and whisltes. One installer tackles the engine wires and running the wire through the firewall & the other ones works under the dash. Make sure you have the more experienced person under the dash so it goes quicker. Just remember that not all vehciles require a two person effort, just the ones that have passenger wire connections and under the hood connections as well. If you have someone there that can prewire the harness for 2nd ACC and type-C door locks & trunk release relays, it will make things go alot faster.
