2002 Ford Windstar Alarm/Remote Start Wiring
Scott105
Member - Posts: 29
Posted: May 05, 2002 at 4:41 PM / IP Logged
 do you happen to have the wiring diagram for this vehicle. It will glady be appreciated.
Platinum - Posts: 12,488
Posted: May 05, 2002 at 9:05 PM / IP Logged
Ford
Windstar
1999-2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
DK. GREEN
IGNITION SWITCH HARNESS *
Ignition  #1:
WHITE/ YELLOW
Ignition #2:
BLACK
Ignition  #3:
VIOLET/ORANGE
IGNITION SWITCH HANRESS **
Accessory:
BLACK/ LT. GREEN
Brake  Light:
RED / LT. GREEN
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
DK. BLUE/LT. GREEN
AT COIL MODULE ***
Parking Lights:
YELLOW/LT. BLUE (-)
AT FRONT ELECTRONIC MODULE ****
Headlights:
OEM Alarm  Disarm:
LT. BLUE/BLACK (-)
16. PIN CONN. LEFT OF STEERING COLUMN
OEM Alarm  Arm:
ARMS WHENEVER THE DOORS
ARE LOCKED.
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * These Vehicles May Be Equipped With Ford's PATS Anti-Theft System. Bypassing Transponder Theft Systems. ** Use Ignition #3 to Drive a Relay and Fuse the Constant +12 Volts of the Relay Seperately at Battery With a Separate 30 Amp Fuse. *** Located Top Left Side Of The Engine
Ford
Windstar
1999-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED
Starter  Kill:
DK. GREEN
Ignition  +12 Volts:
WHITE/ YELLOW
Dome  Lights/Superv:
ORANGE / WHITE (-)
OEM Horn:
DK. GREEN/ ORANGE (-)
8 PIN CONN. LEFT OF STEERING COLUMN
Power  Lock:
LT. BLUE/ORANGE (-)
16 PIN CONN. IN DRIVER'S KICK PANEL
Power  Unlock:
LT. GREEN/ YELLOW (-)
Trunk  Release:
SEE NOTE *****
Alarm  Input Wire:
ORANGE / WHITE (-)
Notes:
**** Located Behind Driver Side Dash Left Of Steering Column. ***** Sliding Door Operation Tan/Lt. Blue (-) At Switch (Same Color For Driver or Passenger Side).
Fruhead
Member - Posts: 11
Posted: January 07, 2003 at 9:24 AM / IP Logged
I'm going to be installing a remote start in one of these vans. I have a 555U transponder unit, and was wondering if this would bypass ford's anti-theft system.
Thanks!
Posted: January 07, 2003 at 9:30 AM / IP Logged
Yes it will.
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
