2004 Chrysler Sebring LX Sedan wiring
kingpiccolo2
Posted: August 06, 2005 at 9:58 PM / IP Logged
I'm looking to install a security system w/ remote start, keyless entry and trunk release. Looking to gain experience with this and help would be greatly apreciated. If you have a wiring diagram or know where I can find one that would be great. Thanks in advance.
thepencil
Gold - Posts: 1,526
Posted: August 07, 2005 at 11:28 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - CHRYSLER / SEBRING SEDAN / 2004 / Remote Start
12volts pink/black (40A), red (20A)   +   ignition harness
Starter yellow   +   ignition harness
Second Starter N/A
Ignition dk. blue   +   ignition harness
Second Ignition dk. GREEN/ red (20 AWG)   +   ignition harness
Third Ignition N/A
Accessory BLACK/ orange   +   ignition harness
Second Accessory BLACK/ white or BLACK/ lt. blue   +   ignition harness
Keysense lt. blue   -   ign. harness or BCM, conn. 1, pin 4
Notes: The BCM (Body Control Module) is attached to the fuse/relay box at the end of the dash on the driver side. Connector 1 is a 16 pin plug on the side of the BCM facing the front of the vehicle.
Power Lock WHITE/ dk. green   +   BCM, conn. 4, pin 15
Notes: Lock is positive trigger thru a 2.7K ohm resistor. Unlock is positive trigger thru a 620 ohm resistor. MUST use relays.
The BCM (Body Control Module) is attached to the fuse/relay box at the end of the dash on the driver side. Connector 4 is a 26 pin plug on the bottom edge of the BCM.
Can also use Directed 457C or 456L interface modules.
Power Unlock same as power lock wire
Lock Motor ORANGE / black   5wi BCM, conn. 4, pin 9
Notes: The BCM (Body Control Module) is attached to the fuse/relay box at the end of the dash on the driver side. Connector 4 is a 26 pin plug on the bottom edge of the BCM.
Unlock Motor dk. blue/white   5wi BCM, conn. 4, pin 13
Parking Lights+ BLACK / YELLOW   +   headlight switch or driver kick
Parking Lights- wht/org (NOT on base model)   -   BCM, conn. 1, pin 5
Hazards same as turn signal wires
Turn Signal(L) lt. green   +   turn signal switch
Turn Signal(R) tan   +   turn signal switch
Reverse Light PURPLE / black or BLACK/ purple   +   driver kick, white 4 pin plug, pin 4
Door Trigger see notes   -   BCM, conn. 4
Notes: The LF door is tan in pin 5, RF door is tan/red in pin 6, LF door is tan/orange in pin 7, and RR door is tan / YELLOW in pin 8. Use all four wires and diode isolate each.
Dome Supervision yellow   -   front of fuse box, 6 pin plug
Trunk/Hatch Pin tan/black   -   BCM, conn. 4, pin 18
Hood Pin N/A
Trunk/Hatch Release BLACK/ white   5wi BCM, conn. 4, pin 1
The trunk release switch wire is BLACK/ white (-) at the switch or at the BCM, conn. 2, pin 3.
Power Sliding Door N/A
Factory Alarm Arm lt. GREEN/ orange   +   BCM, conn. 4, pin 4
Notes: Arm is positive trigger thru a 1.8K ohm resistor. Disarm is positive trigger thru a 750 ohm resistor. MUST use relays.
Factory Alarm Disarm same as factory alarm arm wire
Disarm No Unlock see factory alarm disarm
Tachometer NOT dk grn/org, dk grn/lt grn   ac   any ignition coil or fuel injector
Wait to start N/A
Brake Wire WHITE/ tan   +   brake pedal switch
Parking Brake gray/black   -   back of fuse box, blue 10 pin plug
Horn Trigger BLACK/ red   -   switch or BCM, conn. 1, pin 2
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Sentry Key
Part #: 555CW
Alternate Part1 #: 556UW
Alternate Part2 #: 555U
Notes: Only vehicles with gray keys have the immobilizer.
Door Lock Interface Required:
Yes Type:
Data Bus
Part #: 457CW
Alternate Part1 #: 456LW
Notes:
Be careful whose advice you buy, but be patient with those who supply it.2004 Chrysler Sebring LX Sedan wiring - Last Post -- posted image.
