Peugeot 306 2000 model alarm and central
electron1kid
Posted: August 11, 2005 at 11:49 AM / IP Logged
Hi ,
I would like to ask is anyone knows where the alarm and central locking module are situated for a 306 year 2000 model? and if any diagram is available please
thanks
Jesmond
thepencil
Gold - Posts: 1,526
Posted: August 11, 2005 at 3:38 PM / IP Logged
It's all that I have if it helps you at all.
DIRECTWIRE™ WIRING INFORMATION - PEUGEOT / 306 DIESEL TURBO (UK) / 1997 / Remote Start
12volts
Starter white      ignition harness
Second Starter
Ignition yellow      ignition harness
Second Ignition
Third Ignition
Accessory
Second Accessory
Keysense
Power Lock orange or white    -   under back seat, blk plug
Power Unlock violet or white    -   under back seat, blk plug
Lock Motor
Unlock Motor
Parking Lights+ grey & pink     driver dash, lt brn plug
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger white    -   CDL relay
Dome Supervision
Trunk/Hatch Pin white      at the bootlight
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm red    -   unit behind o/s rear quarter
Factory Alarm Disarm blue    -   unit behind o/s rear quarter
Disarm No Unlock
Tachometer
Wait to start
Brake Wire
Parking Brake
Horn Trigger
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Modules: Not Available
DIRECTWIRE™ WIRING INFORMATION - PEUGEOT / 306 (UK) / 1996 / Remote Start
12volts
Starter blue      ignition harness
Second Starter
Notes: Fuel cut pump is white wire at a double relay module attached to the firewall on the n/side. Module is brown.
Second Ignition
Third Ignition
Accessory
Second Accessory
Keysense
Power Lock orange or white    -   ctrl mod behind rear seat
Notes: Extend to 3 second lock pulse to deadlock.
Power Unlock violet or lt brown    -   ctrl mod behind rear seat
Lock Motor
Unlock Motor
Parking Lights+ red & green      at the steering column
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger grey or yellow    -   loom driver side A pillar
Dome Supervision
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Disarm No Unlock
Tachometer brown pin 4      yel conn. top of the dash
Wait to start
Brake Wire red      brake pedal switch
Parking Brake
Horn Trigger
Memory Seat 1
Memory Seat 2
Memory Seat 3
Be careful whose advice you buy, but be patient with those who supply it.Peugeot 306 2000 model alarm and central - Last Post -- posted image.
