Similar or Not ?
Allen_pytel
Member - Posts: 9
Posted: August 22, 2005 at 10:32 AM / IP Logged
Would anyone know if the stereo wiring for a 2004 GMC Sierra  is the same as a 2004 Chevy Silverado ?  or if anyone would possibly have a stereo wiring diargram for a 04 GMC Sierra  it would greatly be appreciated
CCroadshoptn
Copper - Posts: 67
Posted: August 22, 2005 at 4:41 PM / IP Logged
Radio 12v
Similar or Not ? - Last Post -- posted image.
 orange
 radio harness
Radio Ground BLACK/ white  -  radio harness
Radio Ignition (Class 2 Serial Data)
Radio Illumination N/A
Factory Amp Turn-on pink  +  radio harness
Power Antenna N/A
LF Speaker +/- tan - gray  +,- radio harness   Similar or Not ? - Last Post -- posted image.
RF Speaker +/- lt. green - dk. green  +,- radio harness
LR Speaker +/- brown - yellow  +,- radio harness
RR Speaker +/- dk. blue - lt. blue  +,- radio harness
With it being the Class 2 Serial Data you will need a special harness that comes with a doorchime and data interface box. Ball park $50 any store like best buy or Circuit City should have it. Yes you could run a new acc. wire to the fuse panel and hard wire the rest, but I've been told with out that harness you will run into issues with the dealer or when you go to get your emissions done on using the odb2 connection won't give the proper readings.
hope that helps
Mecp Certified
Double check advice with your Meter.
