2002 Chevy Tracker Remote Starter
dereck
Member - Posts: 28
Posted: December 03, 2002 at 6:52 PM / IP Logged
I was looking for a wiring diagram to install a remote starter on a 2002 Chevy Tracker 4x4. Need to know what color of wire to look for. It is also a standard transmission.
dereck
Member - Posts: 28
Posted: December 03, 2002 at 6:55 PM / IP Logged
Also I need to know does this have a passlock system, or any kind of security system?
securinu
Silver - Posts: 772
Posted: December 03, 2002 at 7:22 PM / IP Logged
no passlock dont have wire colors
Oc768
Member - Posts: 28
Posted: December 03, 2002 at 9:22 PM / IP Logged
Dont quote me on this but:
Tracker/Chevrolet  M.Y. 1999-2000
Start:   BLACK / YELLOW IGNITION SWITCH HARNESS
Ignition  #1:   BLACK/ WHITE IGNITION SWITCH HARNESS
Ignition #2:   YELLOW/BLACK IGNITION SWITCH HARNESS
Ignition  #3:   N/A
Accessory:   BLUE IGNITION SWITCH HARNESS
Brake  Light:   GREEN / WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:   BROWN / WHITE AT IGNITION COIL
Parking Lights:   RED / YELLOW (+) 22 PIN CONN. BEHIND LEFT SIDE DR.DASH
Headlights:   RED OR PINK/BLUE (-) AT HEADLIGHT SWITCH
OEM Alarm  Disarm:   N/A IN SCHEMATICS
OEM Alarm  Arm:   N/A NO OEM ALARM PRESENT
Diesel  Glow Plug:
Clutch  Bypass Wire:
   * Noise Suppressor Filter Located On Driver Rear Of Engine Compartment Beneath Wiper Motor.
Constant  +12 Volts:   WHITE/ GREEN
Starter  Kill:   BLACK / YELLOW IGNITION SWITCH HARNESS
Ignition  +12 Volts:   BLACK/ WHITE IGNITION SWITCH HARNESS
Dome  Lights/Superv:   BLACK/ RED (-) PASSENGER KICK PANEL
OEM Horn:   BLACK (-) STEERING COLUMN HARNESS
Power  Lock:   PINK DRIVER'S KICK PANEL **
Power  Unlock:   PINK/BLACK DRIVER'S KICK PANEL **
Trunk  Release:   N/A
Alarm  Input Wire:   BLACK/ RED (-) PASSENGER KICK PANEL
  **   Negative Pulse Door Lock
dereck
Member - Posts: 28
Posted: December 04, 2002 at 3:40 PM / IP Logged
Were is the clutch bypass wire? Does anyone konw if this is the same as a 2002? If so thanks.
