2002 Saturn SL Alarm/Remote Start Wiring
galantin
Member - Posts: 12
Posted: September 08, 2005 at 9:43 PM / IP Logged
need info for remote start/alarm
thepencil
Gold - Posts: 1,526
Posted: September 13, 2005 at 12:36 PM / IP Logged
SATURN L-SERIES 2002
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|red                 |+ |ignition harness            |
|          STARTER|yellow              |+ |ignition harness            |
|        IGNITION|pink               |+ |ignition harness            |
| SECOND IGNITION|green               |+ |ignition harness            |
|   THIRD IGNITION|lt grn (key sense)*7|- |ignition harness            |
|        ACCESSORY|orange              |+ |ignition harness            |
| SECOND ACCESSORY|brown               |+ |ignition harness            |
|       POWER LOCK|ORANGE / black        |+ |drivers kick panel          |
|     POWER UNLOCK|RED / black           |+ |drivers kick panel          |
|       LOCK MOTOR|gray               |   |drivers kick panel          |
|     UNLOCK MOTOR|tan                 |   |drivers kick panel          |
|    DISARM DEFEAT|tan                 |   |passengers kick panel       |
| PARKING LIGHTS +|brown               |   |steering column             |
|       HEADLIGHTS|blue *6             |- |steering column             |
|     DOOR TRIGGER|*1                  |- |*2                          |
| DOME SUPERVISION|use door trigger    |   |                            |
| TRUNK/HATCH PIN|RED / black           |- |BCM, gray 24 pin plug *2    |
|TRNK/HTCH RELEASE|black               |+ |switch *4                   |
|       TACHOMETER|*3                  |   |*3                          |
|      SPEED SENSE|                    |   |                            |
|       BRAKE WIRE|lt blue             |+ |brake switch               |
|     HORN TRIGGER|black               |- |steering column             |
|           WIPERS|green(L), purple(H) |+ |steering column             |
| LF WINDOW UP/DN|dk blue - brown     |A |switch in center console    |
| RF WINDOW UP/DN|blue - brown        |A |switch in center console    |
| LR WINDOW UP/DN|dk green - purple   |A |switch in center console    |
| RR WINDOW UP/DN|lt green - purple   |A |switch in center console    |
| SUN RF OPN/CLOSE|not recommended     |   |                            |
|   SUN ROOF LIMIT|not recommended     |   |                            |
|        RADIO 12V|orange              |+ |radio                      |
|     RADIO GROUND|black               |- |radio                      |
|     RADIO SWITCH|yellow              |+ |radio                      |
| RADIO ILLUMINATE|brown               |+ |radio                      |
|       LF SPEAKER|tan - gray          |   |radio or amplifier *5       |
|       RF SPEAKER|lt green - dk green |   |radio or amplifier *5       |
|       LR SPEAKER|brown - yellow      |   |radio or amplifier *5       |
|       RR SPEAKER|dk blue - lt blue   |   |radio or amplifier *5       |
Notes:
NOTE: This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. Use DEI part 555t or 555L. *1 The drivers door is gray/black. The other doors are BLACK/ white. Both wires are in the gray 24 pin plug at the BCM. Use both wires and diode isolate each. *2 The BCM is located above the glove box. *3 On the 4 cylinder models, use PURPLE / white at the ignition module on the driver side of the motor. On the 6 cylinder models, at the ignition coils on top of the cylinder head on the drivers side of the motor, use any one of the three wires that is not pink or black. *4 Can also use BLACK/ white (+) at the BCM in the gray 24 pin plug. *5 The amplifier in under the driver side dash above the brake pedal. *6 Low beam is high current negative, must use relay. *7 The lt. green key sense wire at the steering column must see a ground during remote start to keep the SERVICE light from coming on.
Be careful whose advice you buy, but be patient with those who supply it.2002 Saturn SL Alarm/Remote Start Wiring - Last Post -- posted image.
