Should I use 2 relays for fans and amps?
ghart999
Posted: September 15, 2005 at 2:24 PM / IP Logged
I need to power on 3 amps, 2 crossovers and 6 12V fans from my HU remote wire. If I run everything through the same relay, will hte fans introduce electrical noise into the system? Should I put the fans on a separate relay from the components? If I do 2 relays, will they be isolated from eachother coming from the same distro block? Thanks all.
gcorrea
Silver - Posts: 436
Posted: September 15, 2005 at 5:42 PM / IP Logged
i would go ahead and use two relays one for fans and one for the amps and crossovers. no you  could get power from the same source.
gcorrea
KPierson
Platinum - Posts: 3,527
Posted: September 23, 2005 at 10:19 PM / IP Logged
You shouldn't worry about inducing noise on your remote wires.  You are adding a lot of stuff, and didn't give very much information.  You would need to figure out the current draw of the everything, and see if you can fit it on one 30amp relay (shouldn't be a problem).  The big problem will be making sure you use a wire big enough to support the current of the 6 fans and fusing it properly.
If you are using a distribution block (or any other 12 volt source in a car) then the voltage will not be isolated, as all voltage is generated by the alternator.
Kevin Pierson
Monday, August 18, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
