Wiring daytime running lights aftermarket
magicman22
Member - Posts: 6
Posted: October 19, 2005 at 11:24 PM / IP Logged
I have found a few posts regarding this but it they did not fully meet my requirements.  I would like to get some aftermarket driving lights for my car and have them automatically come on when the car is started.  Could someone give some ideas or diagrams for the wiring.  I should not need to mess with the original headlights on the car because they can still be controlled by the existing switch.  Thanks
palouse md
Member - Posts: 20
Posted: October 20, 2005 at 12:01 AM / IP Logged
use a relay triggered by your ignition switch
86- ignition wire
85-ground
30- 12-volts
87- 12-volt output to your lights
87a- empty
remember if you do it this way your bulbs will burn out more often better off using your parking lights trigger.  if positive trigger then hook it to #86 on the relay.  if it is a negative trigger then as follows
86- 12-volts
85- negative input from parking lights
30- 12-volts
87- out to lights
87a- empty
md
magicman22
Member - Posts: 6
Posted: October 23, 2005 at 2:08 PM / IP Logged
what type of relay is used?  spst or spdt   Thanks
ff-mike
Copper - Posts: 199
Posted: October 24, 2005 at 11:00 AM / IP Logged
Seeings the 87a output is not used, it would be a SPST
Friday, November 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
