remote starters
suzuki
Posted: October 23, 2005 at 8:13 PM / IP Logged
How would I install an after market  remote starting system?
Suzuki
thepencil
Gold - Posts: 1,526
Posted: October 23, 2005 at 10:03 PM / IP Logged
If you have not install one before I would say you will need lots of luck.
Other than that the connection is pretty simple. You will need to connect your + 12V power, ignition, starter, accessory, ground, tach, parking light, brake, and hood pin wire.
Be careful whose advice you buy, but be patient with those who supply it.remote starters - Last Post -- posted image.
Platinum - Posts: 12,488
Posted: October 24, 2005 at 9:33 AM / IP Logged
Remote Starter / Alarm Installation How-To Guide: This is a detailed wire-by-wire desription of all the necessary connections required to hook up your remote starter/alarm system into your car, truck, or SUV.
forbidden
Platinum - Posts: 5,354
Posted: October 24, 2005 at 3:56 PM / IP Logged
I hope you know how to use "the force". If you get in over your head starting to read the instructions, stop there and seek out a qualified professional. It is cheaper for them to do the install than it is to repair damaged electronics.
