Cimate control box inside LED's?
tkur
Member - Posts: 27
Posted: October 28, 2005 at 8:08 AM / IP Logged
Anyone know what type of LEDs are used in the inside of GM control panels like the Climate Control panel?  I need to replace a few.  I opened up the box and they are very small.
cowboy21
Copper - Posts: 64
Posted: November 03, 2005 at 5:09 PM / IP Logged
sorry can't help u replace the original but if they are only around 3mm you could maybe just wire your own up and give it ur personal touch, maybe a different color, be able to switch them on and off at will
modest yet effective... ECLIPSE 12", Venom 8"x2, Focal 5 1/2" comp.,Response amps x2 (580WRMS total @ 4Ohms), Pioneer TFT + DVD, good for 148.7dB
Nebey
Member - Posts: 6
Posted: November 13, 2005 at 10:05 PM / IP Logged
I did this in my 98 Civic.  Took out the factory leds, added new leds with a resistor.  I also changed out the lights behind the guage clusters too, with leds and resistors.  changed the buttons on my climate controls too to leds with resistors.  It took a awhile, but I was happy with it. The guage cluster I am re-doing, but its mostly because purple or uv is hard to stare at, at night.
Mike
