adding 6 more sirens
jcx2
Member - Posts: 8
Posted: November 02, 2005 at 3:15 AM / IP Logged
I dont know why but I would like to wire more sirens inside my car, approx 6, my question is how do I wire them up so I have enough power to power them all up. I have a battery back-up and 791xv in the accord right now already, but would powering 6 sirens be too much for the battery back-up? should I wire in another battery backup to power the sirens? I know I need some sort of relay if anyone could give me exact details that would be great. Thanks
menace2sobriety
Silver - Posts: 394
Posted: November 02, 2005 at 4:24 AM / IP Logged
how many amps. is your battery back up???
thepencil
Gold - Posts: 1,526
Posted: November 02, 2005 at 7:54 AM / IP Logged
Relay diagram for connecting more sirens.
Be careful whose advice you buy, but be patient with those who supply it.adding 6 more sirens - Last Post -- posted image.
jcx2
Member - Posts: 8
Posted: November 02, 2005 at 11:16 AM / IP Logged
back-up batter said is 0.7 amp/ hour it is the DEI 520T
Hornshockey
Silver - Posts: 520
Posted: November 02, 2005 at 4:46 PM / IP Logged
I would recommend hooking up one siren directly off the siren output from the brain, then run the rest off of the relay output; that way when the system is working normally, the BBU is only providing current to run one siren and activate the relay and you still have all sirens active. Plus if the power is disconnected, you still have one siren operational.
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
jcx2
Member - Posts: 8
Posted: November 18, 2005 at 3:32 AM / IP Logged
Hey all
After searching through the fourms I get conflicting facts.
this is what I have
viper 791xv
DEI battery backup
DEI backup siren
I want to add 6 more sirens, question is do I connect the postive from the siren to pin 86 or pin 85?
if the BBU is only providing current to run one siren, and if main battery gets cut, all sirens are off, how can I fix this? Can I add a small 12v battery as a backup?
