LCD Flatscreen Install in Van?
Hbo1
Member - Posts: 9
Posted: November 02, 2005 at 9:51 PM / IP Logged
We are planning on purchasing a used conversion van.  We've seen new models with 22" and sometimes 23" LCD widescreen tv's installed in them.  Most of the used vans we've seen have regular tube tv's in them but we'd like to mount a 19" in their place.  I am a novice but have noticed that these LCD monitors/TV's come with a power supply converting it into 12-volt, 4 amps.  Does this mean I can forego the power supply and use 12-volt from a circuit in the van?  Or am I better of just using an inverter and plugging it into that?  But if I used 12-volt, I would like it always on, not with the ignition.  How would I go about this?  Thanks for any help!
Howard
menace2sobriety
Silver - Posts: 394
Posted: November 03, 2005 at 1:39 PM / IP Logged
i cant see any problems with comming from the van for power if you want to have it powerd on with the key off. just run the power wires strait to a constant power. like your battery. with the engine not running you will be at about 10-11 volts with the engine running you will be around 13.9-14.4 volts
Sunday, November 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
