1 to 4 relay?
hamrajw
Member - Posts: 41
Posted: November 03, 2005 at 10:02 AM / IP Logged
I'm trying to find a relay or something similar that will take 1 input and output it to 4 outputs. I want the 4 outputs separated, not just joined together. This is so they can all have different purposes when the relay is off.
KarTuneMan
Platinum - Posts: 7,056
Posted: November 03, 2005 at 1:22 PM / IP Logged
You will need to provide more information about what it is your trying to do in order to get a good answer.
These 4 outputs.....what do you need the to do?
hamrajw
Member - Posts: 41
Posted: November 03, 2005 at 1:57 PM / IP Logged
There's probably an easier way to go about it.
I have an underbody LED kit. tubes. I has a control box to make them light up in different patterns. The power switch on the control box must be pressed for for it to light. I want to have the LEDs to light up when I activate my remote start, and go off when I release the ebrake. I already have a relay wired for that.
The hard part is I would like to be able to control the kit from the control box. The cable from the control has 8 wires. I assume that 4 of those is positive and 4 are negative.
The easiest solution might be to find a way to bypass the switch on the control box.
Thanks for the help.
