03 Silverado R/S - 2nd Acc needed?
blsi
Posted: November 12, 2005 at 11:16 PM / IP Logged
Anyone know what the brown 2nd Accessory wire feeds on a 2003 Silverado 1500HD?  I'm putting in a remote start (Crimestoppers RS-900V) and the wiring list shows the second Acc but the T-harness I have does not bring out the brown wire.  I'm also using the programmable output for the second ignition and am using the negative output that could drive a relay to control the GMSL interface module.  If I need the second Acc any thought on how I could hook it up using a relay from the remote start acc output without the relay being energized the entire time the truck is running?
GMSL module works great by the way- does both driver 1 and driver 2 (using the trunk button on the remote start to trigger the 2nd driver input to the GMSL).
This is my first remote start so thanks for the help.
NowYaKnow
Gold - Posts: 1,217
Posted: November 13, 2005 at 1:08 AM / IP Logged
Most of the time on the GM trucks you do NOT need to energize the brown wire when remote starting. Some times it is necessary though I always try it first without and if no lights stay on your good to go.
Mike
KarTuneMan
Platinum - Posts: 7,056
Posted: November 13, 2005 at 1:43 AM / IP Logged
Power it up......
GMC4x4Guy
Copper - Posts: 117
Posted: December 04, 2005 at 11:12 PM / IP Logged
Can you leave one of the Accy. wires disconnected so the radio doesn't come on? I'm asking because I'm under the impression that the driver's door would need a negative pulse to turn the radio off if the remote start times out.
"Drive it like you stole it"
cntrylvr79
Silver - Posts: 582
Posted: December 04, 2005 at 11:47 PM / IP Logged
If i remember the truck right you do need to power the brown wire.  I think it powers something that has to do with the climate controls.  As for your pulsing of the door trigger to shut the radio off you would be correct in that assumption.
Cause I'm So white and nerdy...
First Class Certi-fried installer
extreme1
Silver - Posts: 1,070
Posted: December 05, 2005 at 9:58 AM / IP Logged
No brown wire required.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
kgerry
Platinum - Posts: 3,455
Posted: December 05, 2005 at 2:39 PM / IP Logged
not needed... also, the proper data type of bypass module ( XK01, 457G, etc) will shut down the rap circuit for you automatically....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Monday, June 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
