Power doors for 96 Caprice
CutDog504
Silver - Posts: 643
Posted: December 14, 2002 at 12:17 AM / IP Logged
I need some help.  A friend of mine just bought a 1996 Chevy Caprice(former police car). He previously had a 1995 Caprice with all power accecories(locks, windows, and mirrors) but he blew up the engine in it, so he ended up buying the 96 from a police auction. Here's where I need help. He took the power doors off the 95 and put them on the 96(cuz the 96 was a bone stock manual model).  Anyways, I need help wiring up the doors to work. Could somebody give me a wiring color diagram for the power locks, windows, and mirrors, and explain how I wire them up. I'm pretty sure I can just wire up the locks to two relays in a positve pusle setup. But the windows and mirrors, I'm unsure of. CAN SOMEBODY HELP ME PLEASE??  Any help appreciated, even if its just wiring colors, or circuit types, or whatever you can give me.
Platinum - Posts: 12,488
Posted: December 14, 2002 at 6:01 PM / IP Logged
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
|       POWER LOCK|lt. blue            |+  |drivers kick panel          |
|     POWER UNLOCK|white               |+  |drivers kick panel          |
|       LOCK MOTOR|gray                |   |drivers door harness        |
|     UNLOCK MOTOR|tan                 |   |drivers door harness        |
|    DISARM DEFEAT|tan                 |   |passengers door harness     |
| PARKING LIGHTS +|brown               |   |headlight switch *1         |
|       HEADLIGHTS|yellow              |+  |headlight switch            |
|     DOOR TRIGGER|white               |-  |underdash light             |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|dk. green *2        |-  |low in drivers kick panel   |
|TRNK/HTCH RELEASE|BLACK/ white         |+  |at switch                   |
|       TACHOMETER|RED / black           |   |4 pin plug below intake *3  |
|      SPEED SENSE|GREEN / WHITE         |4  |radio harness               |
|       BRAKE WIRE|white               |+  |at brake pedal switch       |
|     HORN TRIGGER|black               |-  |steering column             |
|           WIPERS|purple              |+  |L of steering column        |
|  LF WINDOW UP/DN|dk. blue - brown    |A  |at drivers door switch      |
|  RF WINDOW UP/DN|lt. blue - tan      |A  |at drivers door switch      |
|  LR WINDOW UP/DN|dk. green - purple  |A  |at drivers door switch      |
|  RR WINDOW UP/DN|lt. green - purple  |A  |at drivers door switch      |
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
