2003 mustang, viper 550 esp
fosgate2001
Member - Posts: 41
Posted: November 20, 2005 at 11:16 AM / IP Logged
hi just wondering i own a 2003 ford mustange and i am hooking up a viper 550 esp alarm/remote start on it the remote start interface i have is a 556uw just wondering if i hook the red wire to 12 constant the black wire to the body and the blue wire to the alarm - output factory sec. rearm and put the key inside the box and the antenna ring around the ignition switch inside the column then hook up the 4 pack of relays the red to 12 constant the pink to ing the pink/white to 2nd ing purple to starter and orange to acc if this is correct or not and if there is anything else i have to do to get it to work please let me know i would greatly appericate it thanks
KarTuneMan
Platinum - Posts: 7,056
Posted: November 20, 2005 at 11:32 AM / IP Logged
the out put factory security rearm does NOT get hooked to the 556 Your only gonna use Red,Black, and blue. The blue connects to the "status output" from the R/S unit. Its ground while running, and turns on the box with the key in it.
pss5075104
Copper - Posts: 144
just hook red to 12v constant, black to ground and blue to the status output wire witch should be blue or 2nd status ouput wich will be blue\white.
D
MECP First Class Certified Installer.
Nothing is impossable, it's just more expensive.
Saturday, July 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
