2006 Honda Accord remote start
rojoone2
Posted: November 24, 2005 at 7:51 AM / IP Logged
Hello. Has anyone done remote start in a 06 Accord yet. I am wondering if I need to put a full alarm with remote start , or if I can just add a remote start to the factory alarm. Where can I find the wire codes for the Accord?
gus1
Gold - Posts: 1,013
Posted: November 24, 2005 at 6:07 PM / IP Logged
Same as 2005....
Gus
Mike M2
Platinum - Posts: 2,652
Posted: November 25, 2005 at 12:46 PM / IP Logged
The disadvantage of adding a remote start to the factory remote is the remotes don't work after the car is started. After you remote start, you'll have to use a key to enter the car.
Mike M2
Tech Manager
CS Dealer Services
KPierson
Platinum - Posts: 3,527
Posted: November 25, 2005 at 5:47 PM / IP Logged
Not to mention the range of the Accord remote leaves quite a bit to be desired......
Kevin Pierson
