HiPwr HU to factory amp'd speakers
F4Pilot
Copper - Posts: 113
Posted: December 16, 2002 at 10:34 PM / IP Logged
Im hoping someone can help with this.  As a gift, Im giving an aftermarket head unit for a '91 Mercedes 300SEL.  Does anyone know:
1.  Does this model have amplified speakers?  If so:
2.  I was told that you can wire a hi-power head unit with only the + leads to the speakers only to avoid overpowering factory speaker amps??  Is this possible?  If so:
3.  Please send wiring diagram for '91 300SEL.
02 Odyssey / 99 F4
F4Pilot
Copper - Posts: 113
Posted: December 17, 2002 at 1:25 PM / IP Logged
I found some answers.  Some models are amplified, some arent.
If it is factory amp'd - the amps to the left/right side speakers are located in the trunk respectively.  The front speakers are also powered from the trunk amps.
Im told the HU hi-power input will not damage the factory amps.  Would like to find a diagram now, probably only available from the dealer.
02 Odyssey / 99 F4
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
