Tach wire, 2003 Cavalier
w92firebird
Posted: December 11, 2005 at 10:29 PM / IP Logged
Does anybody have pictures of the location of the tach wire on a 2003 Cavalier ? Or a good description on finding it. I know its purple and white but having problems finding it. Any help will be appreciated thanks.
chriswallace187
Gold - Posts: 1,661
Posted: December 11, 2005 at 10:41 PM / IP Logged
On the top of the engine where the ignition module is, you should see a connector toward the driver's side...check there.
C Renner's Auto Electronix
w92firebird
Posted: December 11, 2005 at 10:57 PM / IP Logged
I looked there the closest color was a solid pink not PURPLE / white
chriswallace187
Gold - Posts: 1,661
Posted: December 11, 2005 at 11:31 PM / IP Logged
If there is a white wire there you can probably use that...also the engine harness, which runs along the top of the transaxle(it's like a 2" split loom harness) has the tach wire in there as well.
