Alarm Installations
Fred040773
Posted: December 18, 2002 at 6:21 AM / IP Logged
Do you have wire colors and locations for a 2002 Toyota 4 Runner? If so please E-Mail me at joe@durbanoautomotive.com
fred
Platinum - Posts: 12,488
Posted: December 18, 2002 at 9:29 AM / IP Logged
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|white - WHITE/ red   |+  |ignition harness            |
|          STARTER|GREEN/ black or black|+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|  SECOND IGNITION|blk/red             |+  |ignition harness            |
|        ACCESSORY|blue/red            |+  |ignition harness            |
|       POWER LOCK|BROWN / white         |-  |plug below fuse box *1      |
|     POWER UNLOCK|grn/yel & blu/yel *2|-  |plug below fuse box *1      |
|       LOCK MOTOR|blue/white          |   |driver kick blue 12 pin plug|
|     UNLOCK MOTOR|pink/green          |   |driver kick blue 12 pin plug|
|    DISARM DEFEAT|BLACK / YELLOW        |   |driver kick harness to rear |
| PARKING LIGHTS +|green               |   |dimmer or harness to rear   |
| PARKING LIGHTS -|RED / white           |   |light switch or column      |
|       HEADLIGHTS|RED / yellow          |-  |light switch or column      |
|     DOOR TRIGGER|lt. GREEN/ black     |-  |*3                          |
| DOME SUPERVISION|use door trigger    |-  |                            |
|  TRUNK/HATCH PIN|lt. GREEN/ red       |-  |driver kick 22 pin plug     |
|         HOOD PIN|GREEN/ orange        |-  |*4                          |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
| DISARM NO UNLOCK|yellow/red *6       |-  |steering column             |
|       TACHOMETER|black               |   |*5                          |
|       BRAKE WIRE|GREEN / WHITE         |+  |at switch                   |
|     HORN TRIGGER|GREEN/ red           |-  |steering column             |
|           WIPERS|blue/blk - yel/blue |+  |at switch                   |
|  LF WINDOW UP/DN|lt. green - blu/yel |A  |inside drivers door         |
|  RF WINDOW UP/DN|lt. green - blu/yel |A  |inside passenger door       |
|  LR WINDOW UP/DN|RED / blue - RED / yel  |A  |drivers kick panel          |
|  RR WINDOW UP/DN|yellow -  green     |A  |drivers kick panel          |
| SUN RF OPN/CLOSE|blue/white - white  |A  |at switch or motor          |
|        RADIO 12V|blue / YELLOW         |+  |at radio                    |
|     RADIO GROUND|brown               |-  |at radio                    |
|     RADIO SWITCH|gray                |+  |at radio                    |
| RADIO ILLUMINATE|violet              |+  |at radio                    |
|    POWER ANTENNA|BLACK/ white         |+  |at radio                    |
|       LF SPEAKER|pink - violet       |   |at radio or speaker         |
|       RF SPEAKER|lt.green - blue     |   |at radio or speaker         |
|       LR SPEAKER|black - yellow      |   |at radio or speaker         |
|       RR SPEAKER|red - white         |   |at radio or speaker         |
Notes:NOTE: Some models have an immobilizer system that needs to be bypassed during remote start. Use DEI module 555F or 555U to bypass. *1 The door lock wires will meter while turning the key in the passenger door key cylinder. *2 The GREEN/ YELLOW wire is the key cylinder unlock wire, the blue / YELLOW wire is the unlock detection wire. Use both wires and diode isolate. *2 you must send ground to both wires and diode isolate. *3 behind drivers side junction block in a 13 pin plug. *4 drivers side firewall in a gray 26 pin plug. *5 located in the diagnostic plug on the drivers side of engine compartment. *6 This is the ignition key sense wire. Using the status output wire from the remote start to ground this wire will disarm the alarm without unlocking the doors.
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
