Second fuse box?
n0t0ri0us
Posted: December 24, 2005 at 10:39 PM / IP Logged
Has anyone ever installed a second fuse box? or even heard of this being done? Im looking to make an AUX fuse box to be a central wiring hub with a little bit of proteciton for monitors, second battery, lights, power inverters, and other 12v goodies in my car. Im just trying to clean up all the wires tapped off my cigarette lighter.
Zak
Ween
Platinum - Posts: 1,368
Posted: December 25, 2005 at 6:53 PM / IP Logged
hi,
yes, done it before, numerous times.  you can use the stock radio's switched power lead to trigger a relay that will switch power from the battery.  depending upon how much switched power you require, you may need to use an additional relay with it's coil in parallel with the first one. use 8 or 10 gauge wire to feed the fusebox. make sure to fuse this lead of course.  not hard to do if you have the parts you need.
hope this helps
mark
n0t0ri0us
Posted: December 25, 2005 at 11:12 PM / IP Logged
What should I use for a second fuse box? something out of a motorcycle or ATV? it only needs to have 5-10 fuse slots. Any ideas?
Ween
Posted: December 26, 2005 at 6:37 AM / IP Logged
something such as these would be a start.
http://www.delcity.net/delcity/servlet/catalog?parentid=176&page=1
i'd also fuse the second battery independent of the secondary fuse box wiring.
m
techguy688
Copper - Posts: 55
Posted: December 27, 2005 at 7:29 PM / IP Logged
Second fuse box? - Last Post -- posted image.     Also has a variety of custom wiring and fuse panels to help make a clean installation.
Just because you've done something for a long time doesn't mean you're any good at it.
Cable Ties Rock!
techguy688
Copper - Posts: 55
Posted: December 27, 2005 at 7:31 PM / IP Logged
That didnt look right. try
www.waytekwire.com
Cable Ties Rock!
