is amp big enough for sub?
mgoddard2
Member - Posts: 7
Posted: December 31, 2005 at 1:40 PM / IP Logged
Hi everyone, I have a Pioneer GM-X722 amp and a TS-w1500spl DVC sub,  here are the specs I was wondering if I wire the dvc's in parralel and have a 2ohm sub, will my amp do the job, or do I need to upgrade?  Thanks for your time
Amp details
  • Continuous Power (20Hz-20kHz, 0.04% THD)
    • 2 ch: (4 Ohm) 80Wx2
    • 2 ch: (2 Ohm) 120Wx2
    • 1 ch: (4 Ohm) 240Wx1
  • Maximum Power (EIAJ)
    • 2 ch: (4 Ohm) 160Wx2
    • 1 ch: (4 Ohm) 480Wx1
  • Frequency Response: 10Hz - 50kHz (0,-1dB)
  • Total Harmonic Distortion: 0.004% (1kHz, 4 Ohm)
  • Signal-to-Noise Ratio: 102dB (IHF-A Weighted, at 1kHz)
  • Dimensions: 10" x 2-3/8" x 10-3/8"
Features
  • Bridgeable 1/2/3 Channel Capability
  • 1-Ohm Stable Operation
  • PWM Regulated MOSFET Power Supply
  • Balanced Isolator Input Circuit
  • Gold-Plated Screw-Type Power/Ground Terminals
  • Gold-Plated Screw-Type Speaker Terminals
  • Gold-Plated RCA Inputs
  • Gold-Plated RCA Outputs (Pass-Thru)
  • Top-Mount Controls
    • Variable Crossover: 50-120Hz, -12dB/oct. (LPF/HPF)
    • Bass Boost (60Hz, 0 to +12dB)
    • Hi-Volt Input Level Control (400mV-6.5V)
  • Single Fan Cool
  • Illuminated Logo
SUB specs
  Size10
  Woofer Cone MaterialInterlaced Carbon Fiber/Glass Fiber Reinforced
  SurroundWide-Roll 3- Layer Fiber Woven Radial with Honeycomb Cloth
  Voice CoilDouble 4-Layer (2x4omhs)
  Voice Coil Bobbin4-Slit Glass-Imidez
  Damper (Spider)Y
  Top PlateY
  Projected Pole Yoke with Vented Poleis amp big enough for sub? - Last Post -- posted image.
  Magnet ConstructionDouble Stacked (80oz)
  Basket DesignAluminum Die-Cast
  Gasket1-Piece Rubber
Specifications
  Watts MAX. Music Power1500W
  Watts Nominal Power Handling600W
  Frequency Response18HZ-2500HZ
  Sensitivity87dB (1W/1m)
  Ohm RatingDual Voice Coil Design 2 ohm or 8 ohm
  Recommended Enclosure1.0 Cubic Feet
DYohn
Platinum - Posts: 10,741
Posted: December 31, 2005 at 1:45 PM / IP Logged
Your amp cannot be bridged into 2-ohms.  The only way to safely use this sub and this amp is to wire the VCs in series for an 8-ohm load and bridge the amp (or wire each VC to an output channel separately, which results in the same net effect.)  Will it do the job?  Sure.  Will it drive the sub to it's limits?  No.  Will you like the result?  It depends, try it and see.
mgoddard2
Member - Posts: 7
Posted: December 31, 2005 at 2:01 PM / IP Logged
So this amp would be the better choice? Thanks a lot for your time
BA1500
Voltage10.5 -14 v
Power Output500 watts
Channels1
Frequency Response20-250
Fuse30 Amps
CrossoverYES
ProtectionThermal, Short Circuit, Overload
Max Power Output500 watts
Power @ 4 OHM300
Power @ 2 OHM500
Power @ 1 OHMNOT RECCOMENDED
Power @ .5 OHMNOT RECOMMENDED
Signal To Noise Ratio>90db
Battery Voltage Range10.5-14.4
Crossover Range40Hz - 200
Bass EQYES
Auxillary Fuseno
Remote Controloptional
RCA Inputyes
Auto Turn Onno
Subsonic Filterno
DYohn
Posted: December 31, 2005 at 2:15 PM / IP Logged
Looks like it's 2-ohm stable, so sure.  Is it a Bazooka?  You can probably get a better brand than that.  How much can you spend?
