Wiring Diag. '98 Dakota
ultimateshrub
Member - Posts: 22
Posted: December 22, 2002 at 2:53 PM / IP Logged
Hi
I am attempting to install an Astrostart 1105 car starter in a 1998 Dodge Dakota and I am looking for the wiring diagram that I will need as well as any advice that members might be able to offer.
Brad
Platinum - Posts: 12,488
Posted: December 24, 2002 at 11:43 PM / IP Logged
|              12V|red or pink/black   |+  |ignition harness            |
|          STARTER|blue / YELLOW         |+  |ignition harness            |
|         IGNITION|dark blue           |+  |ignition harness            |
|        ACCESSORY|BLACK/ orange        |+  |ignition harness            |
| SECOND ACCESSORY|BLACK/ white         |+  |ignition harness            |
|       POWER LOCK|org/pur or grn/blk  |+  |drivers kick panel          |
|     POWER UNLOCK|pink/purple *1      |+  |drivers kick panel          |
| PARKING LIGHTS +|BLACK / YELLOW        |   |behind fuse box             |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|light green         |+  |steering column             |
|     DOOR TRIGGER|yellow              |-  |behind fuse box             |
|  TRUNK/HATCH PIN|                    |   |                            |
|         HOOD PIN|                    |   |                            |
|TRNK/HTCH RELEASE|                    |   |                            |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|BLACK/ orange        |-  |drivers door harness        |
|       TACHOMETER|blk/gry or gry/blk  |   |coil pass. sid of eng.      |
|       BRAKE WIRE|WHITE/ tan           |+  |at brake switch             |
|     HORN TRIGGER|BLACK/ red           |-  |steering column             |
|           WIPERS|RED / yellow          |+  |wiper switch                |
|  LF WINDOW UP/DN|lt. blue - white    |A  |drivers door switch         |
|  RF WINDOW UP/DN|brn/wht - ppl/wht   |A  |drivers kick panel          |
|  LR WINDOW UP/DN|                    |   |                            |
|  RR WINDOW UP/DN|                    |   |                            |
Notes:
*1 Vehicles with keyless entry, have to 5 wire the unlock wire.
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
