2001 Ford Explorer Alarm/Remote Start/Stereo Wiring
Json22s
Posted: December 23, 2002 at 1:51 PM / IP Logged
trying to install viper 550 remote start on 2001 ford explorer, need diagram
trusdamanr
Copper - Posts: 116
Posted: December 23, 2002 at 9:10 PM / IP Logged
12volts
2001 Ford Explorer Alarm/Remote Start/Stereo Wiring - Last Post -- posted image.
yellow
ignition harness
StarterRED / lt. blue + ignition harness
Second Starternone
Ignitionlt GREEN/ purple + ignition harness
Second Ignitionnone
Third Ignitionnone
Accessorybrown + ignition harness 2001 Ford Explorer Alarm/Remote Start/Stereo Wiring - Last Post -- posted image.
Second AccessoryBLACK/ green + ignition harness
Keysense
Power Lockpink / YELLOW driver kick panel 2001 Ford Explorer Alarm/Remote Start/Stereo Wiring - Last Post -- posted image.
Power Unlockpink/lt green driver kick panel 2001 Ford Explorer Alarm/Remote Start/Stereo Wiring - Last Post -- posted image.
Lock Motorpink/black driver kick panel
Unlock MotorRED / orange driver kick panel
Parking Lights+wht/blk or brown headlight switch or DKP
Parking Lights-WHITE/ purple 2001 Ford Explorer Alarm/Remote Start/Stereo Wiring - Last Post -- posted image.
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger - 2001 Ford Explorer Alarm/Remote Start/Stereo Wiring - Last Post -- posted image.
Dome Supervisionuse door trigger
Trunk/Hatch PinWHITE/ purple - driver kick panel
Hood Pintan/lt.green - driver kick panel
Trunk/Hatch Releasenone
Power Sliding Door
Factory Alarm Armarms on lock 2001 Ford Explorer Alarm/Remote Start/Stereo Wiring - Last Post -- posted image.
Factory Alarm Disarmdk. GREEN/ purple - driver kick panel
Disarm No Unlocknone nonnone
Tachometertan / YELLOW PCM 2001 Ford Explorer Alarm/Remote Start/Stereo Wiring - Last Post -- posted image.
Wait to start
Brake Wirelt green + driver kick panel
Parking Brake
Horn Triggeryellow/lt. green - steering column
notes________
1.ACC-
Two brown wires at switch, both have to be powered for remote start.
2.door lock-
On models with keyless entry the doorlocks are negative trigger. Without keyless entry they are 5wi reverse polarity.
3.door unlock-
The GEM in this vehicle shuts down after the doors have been locked for a certain time period, to wake-up the system refer to directfax document #1093.
4.parking lights-On early production vehicles it is in the driver kick panel, in the harness to the rear of the vehicle. On late production vehicles it is behind the glove box at the central security module.
door trigger-
In the drivers door harness find yellow/black for the drivers door. In the drivers kick panel find lt. GREEN/ YELLOW for the drivers rear door. In the passengers kick panel find gray/red for the passenger front door, and pink/lt. blue for the passengers rear door. All four wires are negative trigger and must be diode isolated together. Refer to directfax document #1076 for wiring information.
Json22s
Posted: January 03, 2003 at 2:30 AM / IP Logged
Trying to install viper 550 need diagram
Platinum - Posts: 12,488
Posted: January 03, 2003 at 11:07 PM / IP Logged
|              12V|yellow              |+  |ignition harness            |
|          STARTER|RED / lt. blue        |+  |ignition harness            |
|         IGNITION|lt GREEN/ purple     |+  |ignition harness            |
|        ACCESSORY|brown *1            |+  |ignition harness            |
| SECOND ACCESSORY|BLACK/ green         |+  |ignition harness            |
|       POWER LOCK|pink / YELLOW         |*8 |driver's kick panel         |
|     POWER UNLOCK|pink/lt green *9    |*8 |driver's kick panel         |
|       LOCK MOTOR|pink/black          |   |driver's kick panel         |
|     UNLOCK MOTOR|RED / orange          |   |driver's kick panel         |
|    DISARM DEFEAT|pink/orange *2      |   |driver's kick panel         |
| PARKING LIGHTS +|wht/blk or brown    |   |headlight switch or DKP     |
| PARKING LIGHTS -|WHITE/ purple        |   |*3                          |
|       HEADLIGHTS|RED / yellow          |+  |headlight switch            |
|     DOOR TRIGGER|*4                  |-  |*4                          |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|WHITE/ purple        |-  |driver's kick panel         |
|         HOOD PIN|tan/lt.green        |-  |driver's kick panel         |
|  FCTRY ALARM ARM|arms on lock *5     |   |                            |
|FCTRY ALRM DISARM|dk. GREEN/ purple    |-  |driver's kick panel         |
|       TACHOMETER|tan / YELLOW          |   |PCM *6                      |
|      SPEED SENSE|gray/black          |8  |PCM *6                      |
|       BRAKE WIRE|lt green            |+  |driver's kick, brake switch |
|     HORN TRIGGER|yellow/lt. green    |-  |steering column             |
|           WIPERS|wht & dk.blu/org *7 |+  |wiper motor or relay        |
|  LF WINDOW UP/DN|wht/blk - red       |A  |at motor in dr door         |
|  RF WINDOW UP/DN|wht/yel - tan/lt.blu|A  |sw dr door or dr kick       |
|  LR WINDOW UP/DN|yel/lt.blu - gry/org|A  |sw dr door or dr kick       |
|  RR WINDOW UP/DN|yel/blk - RED / blk   |A  |sw dr door or dr kick       |
|        RADIO 12V|lt GREEN/ purple     |+  |at radio                    |
|     RADIO GROUND|black               |-  |at radio                    |
|     RADIO SWITCH|yellow/black        |+  |at radio                    |
| RADIO ILLUMINATE|RED / black           |+  |at radio                    |
|       LF SPEAKER|org/lt grn-lt blu/wh|   |at radio                    |
|       RF SPEAKER|wht/lt grn - grn/org|   |at radio                    |
|       LR SPEAKER|tan/yel - gry/lt blu|   |at radio                    |
|       RR SPEAKER|org/red - brn/pnk   |   |at radio                    |
Notes:
NOTE: Some models of this vehicle are equipped with PATS (Passive Anti Theft System). Use DEI module 555U to over-ride during remote start.  *1 Two brown wires at switch, both have to be powered for remote start.  *2 You may also use the pink/green power unlock wire.  *3 On early production vehicles it is in the driver kick panel, in the harness to the rear of the vehicle. On late production vehicles it is behind the glove box at the central security module.  *4 In the drivers door harness find yellow/black for the drivers door. In the drivers kick panel find lt. GREEN/ YELLOW for the drivers rear door. In the passengers kick panel find gray/red for the passenger front door, and pink/lt. blue for the passengers rear door. All four wires are negative trigger and must be diode isolated together. Refer to directfax document #1076 for wiring information.  *5 Arms on lock only with door open. It is necessary to send a signal to door trigger as well as lock to arm factory alarm.   *6 The PCM is located at the top of the firewall towards the passenger side, the tan / YELLOW tach wire is also found at the back of the instrument cluster. Can also use any tan/stripe at the coil pack.  *7 Also found yellow/white (-) at the firewall connector.  *8 On models with keyless entry the doorlocks are negative trigger. Without keyless entry they are 5wi reverse polarity.  *9 The GEM in this vehicle shuts down after the doors have been locked for a certain time period, to 'wake-up' the system refer to directfax document #1093.
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
