2006 jeep liberty, alarm w/keyless wiring
raulromo34
Member - Posts: 28
Posted: January 12, 2006 at 12:03 AM / IP Logged
looking for wiring diagram to install car alarm w/keyless entry....vehicle has keyless on key, but want  to add actual alarm system to vehicle.  can anyone help???
football fanatic
desh187
Copper - Posts: 310
Posted: January 12, 2006 at 1:05 AM / IP Logged
12 volt    -red              @ignition harness
ignition   -pink/lt green
starter    -lt blue/red
dome light -driver door violet 26 pin gray conn
           -front right violet/white
           -rear left   violet/gray 22 pin gray conn
           -rear right violet / YELLOW
all above(-) door trigger wires at bcm-behinddriver dash left of steering column.diode isolate,band side faces oem wires.
trunk/hatch -violet / YELLOW gray 26pin coo at bcm.
park lights -pink/red(-)steering column harness,use relay-must see ground thru 900 ohm resistor
power lock/unlock -tan/blue single wire,42 pin green conn @junction block
chassis ground thru 1.4k ohm resistor to lock,chassis ground thru 425 ohm to unlock.
trunk release -lt GREEN / WHITE(-)at bcm conn 1
horn        -dk GREEN/ violet(-) steering column harn.
tach -black any injector
ign 2 -pink / YELLOW test for correct one,2wires present.
accessories-pink / YELLOW
brake light -WHITE/ tan(+)at switch above brake pedal
vehicle has immobilizer on key,use bypass
Sunday, July 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
