2001 Nissan Frontier 4 dr, remote start
holtonch
Posted: February 01, 2006 at 2:24 AM / IP Logged
I need the wiring color codes for a complete remote start system for my friends 2001 Frontier 4 dr V6 w/ power everything PLEASE!
notoriouswill
Member - Posts: 32
Posted: February 01, 2006 at 10:44 PM / IP Logged
12volts      green       +       ignition harness
Starter      BLACK / YELLOW       +       ignition harness
Second Starter      GREEN/ YELLOW       +       ignition harness
Ignition      BLACK/ white       +       ignition harness
Second Ignition
Third Ignition
Accessory      RED / yellow       +       ignition harness
Second Accessory      WHITE/ blue       +       ignition harness
Notes: Not required for remote start.
Keysense
Power Lock      yellow       -
Notes: Located at the Smart Entrance Control Unit above the hood release in the drivers kick panel. The door lock wires only meter when turn the key in either door key cylinder.
Unlock requires a double pulse. On vehicles without the factory alarm, can also find lt. GREEN/ red for lock and brown for unlock.
Power Unlock      yellow/red       -
Lock Motor      blue
Unlock Motor      GREEN / WHITE
Parking Lights+      blue/red             steering column
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger      RED / black       -
Notes: If equipped with factory dome light delay, use GREEN/ red(-) for the drivers door and GREEN/ black(-) for the passenger door. Diode isolate each wire. The RED / black may also be found in the drivers A pillar.
Dome Supervision
Trunk/Hatch Pin
Hood Pin      BLACK/ pink       -
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm      arms with lock
Factory Alarm Disarm      disarms with unlock
Disarm No Unlock
Notes: A single pulse to the unlock wire will disarm the factory alarm without unlocking the doors.
Tachometer      pink/blue or black             instrument cluster or ECM
Notes: The ECM is located below the heater box to the right of the accelerator pedal, behind trim panel. The tach is in the top row, 3rd pin left of center of the plug. The VSS is in the 2nd row from the top, 4th pin right of center.
Wait to start
Brake Wire      BROWN / red       +       brake pedal switch
Parking Brake
Horn Trigger      lt grn/red or brown       -       steering column
1 Memphis Mojo 15
1 Memphis 4000 watt amp
1 Memphis 75watt 4 channel amp
2 Memphis 6.5" MSQ's
2001 Nissan Frontier 4 dr, remote start - Last Post -- posted image.
