2005 Aveo VSS PPM, Tach Wires?
duramax3500
Posted: February 05, 2006 at 12:18 PM / IP Logged
Hi,
I've got a 2005 chevy aveo that i'm installing a ccs-100. I would appreciate any help that i could get regarding the location of the vss and tach wires and the correct ppm setting for this vehicle.
Thank you for your help,
duramax3500
sparkie
Platinum - Posts: 2,061
Posted: February 05, 2006 at 2:56 PM / IP Logged
The VSS wire is GREEN / WHITE either at the three pin plug off the transmission at the back of the motor near the firewall on the driver's side or it may be at pin 14 of the gray connector plug under the driver's side dash. It goes through the firewall. There is a white wire in cavity 15 of the same plug which is tach.
sparky
Sunday, May 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
