Viper 160 XV in a 98 Land Rover Discovery
Vyse
Member - Posts: 28
Posted: February 23, 2006 at 10:19 PM / IP Logged
Tried putting one in last week and couldn't disarm the factory alarm. Then negative alarm disarm pulse from the 160xv wouldn't work. Any ideas? Anyone been able to get around this?
mo12v
Posted: February 24, 2006 at 8:31 AM / IP Logged
May need Relays for stronger GROUND Pulse
MO
1994honda2005
Member - Posts: 11
Posted: February 24, 2006 at 8:41 PM / IP Logged
there is no doubt that you need to add relays in order to make the FAD work. the arm wire will also lock the doors and the disarm wire will unlock the doors but you def need relays. if you dont know how to set it up, just hit me up
Friday, July 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
