2006 Dodge Sprinter Door Locks
nautix
Posted: March 03, 2006 at 10:17 AM / IP Logged
I'm putting an alarm in a 2006 Dodge Sprinter. Having problems with the door locks. Door locks are a one wire system, in which, both unlock and lock are both straight negative triggers to the same wire. I've isolated lock and unlock with relays; however, when it's hooked up, it lock and unlocks with one button on the remote.
I've also gone to the door lock motor wires (5 wire). All the doors lock but only the driver's side will unlock.
Does anyone know how to wire these properly. Thanks.
audiophd
Member - Posts: 46
Posted: March 03, 2006 at 12:24 PM / IP Logged
i have done one of those vehicles. what you have to do is go under the driver side seat and find the lock wires there. those will control pass and rear doors.  you will still need the ones you caught at the dirvers door. 5 wire both and run to lock and unlock wires. and what i did was rewired the switch to go directly to the relys so that when it was pressed up it would unlock and down was lock.
