Pillar/Curtain Airbag Antenna Routing
Twelvoltz
Platinum - Posts: 2,384
Posted: March 11, 2006 at 6:22 PM / IP Logged
I am curious to see what others do. How do you run your antenna wire for your systems when you have a vehicle that has pillar/side curtain airbags? I have done a couple, and make every effort to not put the wire in the way of where the bag would deploy, but have found that in some vehicles there is no other option.
I was wondering what everyone else thinks/does.
cntrylvr79
Silver - Posts: 582
Posted: March 11, 2006 at 8:53 PM / IP Logged
Generally try to route it so that if the bag/curtain deployed it wouldn't get in the way, though I've seen what happens to an antenna wire when the bag goes off.  The bag rips the antenna in half.
Cause I'm So white and nerdy...
First Class Certi-fried installer
xscash
Copper - Posts: 317
Posted: March 11, 2006 at 9:53 PM / IP Logged
i think if the bags deploy....you eill have bigger problems than weather or not the remote starter will still work.
no, seriously i just run it right in the rubber gasket and along the very top of the a piller trim
