2004 Suburban Radio
jasonglenn
Posted: March 13, 2006 at 9:27 AM / IP Logged
I just bought a Sony (aftermarket) cd player for my 2004 Chevrolet suburban. I need a wiring diagram for the factory wires coming from the dash. I also have a dvd/tv installed that runs through my player for sound. Is there something extra that I need to do to hook up the Sony player and have sound for my dvd/tv?
I once heard two ladies going on and on about the pains of childbirth and how men don't seem to know what real pain is. I asked if either of them ever got themselves caught in a zipper.
xscash
Copper - Posts: 317
Posted: March 13, 2006 at 4:48 PM / IP Logged
ok , if royr tuner has audio in pu then just plug the audio from the dvd in there and if not then you need a fm modulator.
here is the wire colors
2004 CHEVROLET SUBURBAN 4DR SUV WITH 5.3L ENGINE AND STANDARD AUDIO SYSTEM
2004 Suburban Radio - Last Post -- posted image.
Audio/Mobile Video
WIRECOLORPOLARITYLOCATION
Battery ORANGE (+) RADIO HARNESS
Accesory
  THE RADIO HARNESS DOES NOT PROVIDE A SWITCHED POWER SOURCE. RUN A WIRE TO THE FUSEBOX FOR SWITCHED POWER. THE ACCESSORY TURN-ON AND AMPLIFIER TURN-ON ARE CONTROLLED BY THE CLASS 2 SERIAL NETWORK.
Ground BLACK/ WHITE (-) RADIO HARNESS
Illumination BROWN (+) RADIO HARNESS
Dimmer GRAY (+) RADIO HARNESS
LF Speaker (+) TAN
LF Speaker (-) GRAY
RF Speaker (+) LIGHT GREEN
RF Speaker (-) DARK GREEN
LR Speaker (+) BROWN
LR Speaker (-) YELLOW
RR Speaker (+) DARK BLUE
RR Speaker (-) LIGHT BLUE
Steering Cntrls OPTIONAL
  THIS VEHICLE MAY BE EQUIPPED WITH OPTIONAL ONSTAR® TELEMATICS EQUIPMENT. USE AN APPROPRIATE INTEGRATION HARNESS OR INSTALLATION PROCEDURE TO ENSURE PROPER FUNCTION OF THIS EQUIPMENT.
Speed Cntrl OPTIONAL
Radio Security YES
  XS
geepherder
Platinum - Posts: 3,668
Posted: March 13, 2006 at 7:07 PM / IP Logged
Jason,
I like that signature.  I'd recommend using a wiring harness for your vehicle, which you can get at your stereo shop.  You can get a regular harness, and run your own accessory lead, or you can buy a module which supplies an accessory lead (and retains the factory chimes and OnStar functions, etc.).
