Specs and how-to needed
wiretap
Posted: March 19, 2006 at 12:09 PM / IP Logged
I have two ppi amps A200, A300 I was wondering are these decent amps and do anybody have the specs for them. I have two 12" subs kenwood KFC-WSO2 750 watts 4 ohms, Punch DVCRFP-1212 4 ohms, how would i go about hooking that up until i can get the right set up and could u explain dual voice coil is it louder, deeper bass, what is it importance please help!
I have a 1993 Ford Tempo jus want to know can I power a amp from the factory radio if so how and what do i need please help
stevdart
Platinum - Posts: 5,816
Posted: March 24, 2006 at 9:26 PM / IP Logged
These amps are the beautiful Art series, but they're old.  You are buying used amps, so be careful.  Ask the seller about the specs.
See the woofer wiring help in the left column.  It will include guidance for the type of amplifier suited for the situation.
Dual voice coil is not louder, deeper, or anything else.  It's two voice coils instead of one.  The subwoofer's RMS rating combines the capacity of both coils.  You will not get individual voice coil power handling statistics in the specs.  The woofer is rated for what it is.
No, you can't power an amp from the factory radio.  Find a switched 12 volt wire (on with accessory, off when the key is off) to hook up the turn-on wire for the amp.  The power wire for the amp goes directly to the battery.  Grounding is done to the vehicle chassis (sheet metal).
willdkartunes
Copper - Posts: 250
Posted: March 24, 2006 at 10:47 PM / IP Logged
Correct me if I'm wrong, but it sounded like you mentioned two different subwoofers in your post. I hope you don't plan to hook up two different subwoofers together as this would be a bad idea....
Do whatever makes you happy in life without diminishing the happiness of others
